r-5 return leg
nickia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Topic: r-5 return leg
    Posted: 17 Dec 2019 at 6:43pm
r-5 return leg the head where the chain sprocket is driving is there a roll pin that hold the sprocket to the shaft or is what im seeing is a flat spot on the shaft that a set screw sets to marry the sprocket to the shaft? there isn't a key way involved in marrying to the the shaft is there? my shaft turns inside the sprocket
