Wc tire suggest
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Topic: Wc tire suggest
    Posted: 17 Dec 2019 at 7:34am
Ok bought a stock original wc for my girlfriend to pull with at 3000 and 3500 3.5 mph its getting 175 govner spring and d17 weights to get the rpms up it’s got 13.6 28 on it now will the speed be ok with 15.5 38 ? I also have a set 18.4 26 I can build light spoke wheels for
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2019 at 8:17am
. She’s definitely a keeper she spent several hours Sunday power washing years of grease and dirt off
Edited by bradley6874 - 17 Dec 2019 at 8:19am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2019 at 10:51am
Bradley,
 As long as your pulling rules allow those sizes you should be good to go! Some of the pulls I go to they pretty fussy on tire sizes. Here theyt allow one sire size over stock. So We have several WD series tractors with the 14.9's
Someone like Dr. Allis can give you the speed info with different tire sizes. Me not so much.
Hey good looking tractor, and it sounds like she is excited about it too! Will look forward to some pulling pictures as you progress with the tractor and your season!
Reminds me I need to go finish those rim mods for the WD.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2019 at 10:55am
Plans are for Harrisburg farm show Jan 8 debut our rules here are black round and made out of rubber either cut or not cut
Edited by bradley6874 - 17 Dec 2019 at 10:57am
frnkeore View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote frnkeore Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2019 at 11:35am
I ran some numbers for you, using Nebraska Tractor Test info, for tire size and RPM.
The numbers result in the difference between 1300 rpm vs 1750 rpm and 11.2 x 24, WC tires, 43" in dia. But you may have to multi ply these numbers by 1.075, because they list the steel, 40" wheels, with the same 2.5 & 3.5 mph, for first and 2nd gear as the rubber 11.2's.
1st gear stock, 2.5 mph @ 1300 rpm:
18.4x26 = 4.47 @ 1750
15.5x38 = 4.87
2nd gear stock, 3.5mph @ 1300 rpm:
18.4x26 = 6.25 @ 1750
15.5x38 =  6.82
Edited by frnkeore - 17 Dec 2019 at 11:40am
Frank
1959 D17 Series I #24001+, '59 D14
'55 & '59 Ford 850 & 861
Ferguson TO 35 Deluxe, Oliver 70 and 5 more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2019 at 12:39pm
15.5 X 38's on a WC with 30 HP won't work will they ?? You'll kill the engine most of the time in LOW gear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2019 at 1:33pm
My question is more will the gearing work at 3.5 with 38 inc tires with more power or is the gearing just to high ....and something else need to change
Edited by bradley6874 - 17 Dec 2019 at 1:33pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2019 at 2:22pm
3.5 MPH on any standard geared WC works just fine with 15.5 x 38 rear tires IF YOU HAVE ENOUGH ENGINE TO HANDLE IT.
Post Options Post Options   Thanks (0) Thanks(0)   Quote frnkeore Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2019 at 3:31pm
For your combo, 3.5 mph, will put you at 1370 rpm with the 18.4's and 1258 rpm with the 15.5's.
I think you would be better off, with the stock cam and take the engine to, 4 1/8 x 4 1/2 (240.55 CI), and use a bigger carb.
At least you'll have your power at the 3.5 mph.  I think it would work ok. At 5800 lb, I spin my tires (16.9x28), pretty easy with my stock D17.
Oh, and get the engine to at least 9/1 compression.
Edited by frnkeore - 17 Dec 2019 at 3:36pm
Frank
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2019 at 8:54pm
Thanks frnkeore will probly stay with the 28 untill the stroker is finished up then change to 38 with All THE POWER DR SAYS I NEED
alan-nj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alan-nj Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2019 at 6:53am
Don't forget you need wheelie bars for the Farm Show
If ignorance is bliss, than happy days are here again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2019 at 11:51am
Yea alan our club requires them on ALL tractors. Slow fast dosent mater.... that rule lowered our insurance cost
This page was generated in 0.175 seconds.
