Different way to pump tires!
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Topic: Different way to pump tires!
    Posted: 16 Dec 2019 at 7:03pm
https://lacrosse.craigslist.org/grd/d/tomah-antique-collectable-tractor-tire/7029836122.html   Never have seen anything like this before. Were these common?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2019 at 7:07pm
Antique and collectible...........he should be asking a lot more. IRRC those tire inflators are still available. Would come in handy of some of the older equipment.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2019 at 7:40pm
I've got a couple of those around here somewhere.  Haven't used one for a long time.
HaroldOmaha View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HaroldOmaha Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2019 at 8:24pm
I had an IH air hose with 4 different adapters one time. used it with my 53 Ford
festus51 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote festus51 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2019 at 9:04pm
I remember those.  Dad had one because we did not have an air compressor.  I have always wondered or thought you were creating an explosive tire with the gas fumes going in.
We the unwilling Led by the unqualified Doing the impossible for the Ungrateful
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2019 at 9:27pm
I had a JD pump, mounted on PTO.
I might have it still, cant recall where I stored it.
A neighbor had one, kept it on his rake tractor while custom baling for us and others.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2019 at 9:28pm
Those had flapper valves in them, they drew in fresh air into the cylinder, not threw the carburetor, and then pushed it into the tire.
Dusty
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2019 at 11:11pm
They weren't just found in tractors- they were commonly found in the trunk of just about anything from a 29 Ford A on up to the mid '60's...
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2019 at 11:54pm
The one my neighbor had used the air going through the carb, worked ok but you got the gas in the tube too which wasn't good for the life of the tube.
Allis Express participant
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2019 at 12:19am
I've used one, it was probably 1969, on the farm to air up a tire.
I guess I shoulda mentioned that I used it with a WD45 to air up tires.
Edited by john(MI) - 18 Dec 2019 at 1:04am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2019 at 5:00am
These were also popular, back in the day...Wink
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2019 at 5:24am
I assume the valves were in the piston
I am still confident of this;
Wait for the Lord;
marion View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote marion Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2019 at 6:51am
had a boy work for me in the 80's, drove a late 60's ford, Tires were in so bad shape he left the thing plugged into one cylinder and would air all tires up at night when time to go home
ford8nwd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ford8nwd Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2019 at 8:11am
I also had a JD PTO pump, worked well, but very slow.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2019 at 10:48am
Had not thought of that method of filling tires in years. The adapter and hose where under the seat in the pickup at all times. I don't remember dad ever having hand pump to fill tires. I am sure the one here had 2 or 3 different thread sizes to fit any spark plug size they had back in the day.
Anyone here with more than a big lot in town that does not have a air compresser today?Many of us have 2 or more. The first compresser on the ranch showed up right after the gooseneck stock trailer. Dad had away of getting around out in the hills without 4 wheel drive.LOLThat was a waste of money in his eyes. But one of his tricks was letting air out of the rear tire to were they had a big bulge. So the compresser was a big help to get the 15 psi back to 60 to haul 10 cows.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2019 at 11:14am
Marion,, just my opinion, but if you had the money to pay him , surely you could've helped him with tires,,
Greg (Hillsboro, OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Greg (Hillsboro, OH) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2019 at 11:32am
like Festus, we had one as we didn't have a compressor either.   They did work pretty well.
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2019 at 11:30am
We have a JD as well. Used it once. That's enough.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2019 at 6:03pm
You only had to forget it was hooked up once.  While you were fixing the bale knotter or something else.  NEVER do that again!
Then there's the one you hooked to the milk line to do chores when the power was out....
This page was generated in 0.375 seconds.
