715B backhoe
NomoreJohnDeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NomoreJohnDeere Quote  Post ReplyReply Direct Link To This Post Topic: 715B backhoe
    Posted: 15 Dec 2019 at 5:58pm
not mine
claims 4 speed trans out
anybody looking for parts or project?
HD3
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2019 at 7:23am
It's a 715 not a 715B. Borg and Beck trans. May just be low in oil
I had a 715 and now a 715B for the past 32 years
Edited by Calvin Schmidt - 16 Dec 2019 at 7:24am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2019 at 9:17am
it has a 4 speed geared trany - and a fwd/rev clutch pack and torque converter - so more than likely the clutch pack needs replacing or is worn - a common problem is the clutch pack -
david a View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote david a Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2019 at 7:10pm
if it don't move in any of the gears, chance is it's the shuttle. check fluid. There is a  filter up front for the shuttle, and one in the drain plug hole., there are a few 1/8 NPT test ports on the shuttle. make sure you have at least 100 psi at them. Just been though this had a broken piston on the forward clutch and bad front pump, along with torque converter. Parts are getting hard to come by on the WG shuttle. the trans is a truck trans. for me I'm selling the old girl getting too hard to find parts for
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2024 at 11:09pm
The forward / reverse unit was used in Marine use along with the torque converter .
Check marine supply companies for parts
Edited by Coke-in-MN - 10 Aug 2024 at 11:16pm
KRAKMT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRAKMT Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2024 at 7:20am
Not to hijack this thread but does anyone’s 715 have a remote throttle for backhoeing?
Can someone post a pic and explain the linkage?
I am currently using a bungy strap across the foot pedal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2024 at 4:54am
Yes there is a cable running from backhoe council to the pump throttle linkage to control engine speed when hoe is in use .
