7045 Westendorf brackets
bpete View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bpete Quote  Post ReplyReply Direct Link To This Post Topic: 7045 Westendorf brackets
    Posted: 15 Dec 2019 at 11:42am
Have a 7045 with a ta46 Westendorf loader. Bought loader used & brackets weren't correct, they had to cut the side pa else to fit the loader brackets. Redoing things 11 years later. Curious as if anyone would have the correct brackets laying around. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2019 at 3:18am
contact westendorf manuf in Onawa IA
Post Options Post Options   Thanks (0) Thanks(0)   Quote bpete Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2019 at 5:22pm
Edited by bpete - 17 Dec 2019 at 5:24pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote bpete Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2019 at 5:23pm
Originally posted by bpete bpete wrote:
Thanks kinda already knew that. Was hoping to find used before ordering new.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2019 at 8:04pm
they might have a left over sitting around there, maybe go for cheap?
johnkc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote johnkc Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2019 at 8:53am
not selling mine but let me know if you need pics
I support the development of hybrid automobiles and alternative fuels as I need DIESEL fuel for my ALLIS CHALMERS!
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2019 at 9:33am
When I put mine on the 7045, holes had to be drilled for the fuel pump bolts in the right hand frame rail. I would like to know what tractor your brackets did fit.
SilverBullet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SilverBullet Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2020 at 9:18pm
Bpete,
Sorry to say that I don't have extra brackets.
Do you know how they hooked up the hydraulics for that loader?
I have a 7045 with a loader that the hydraulics were not original and I'm having problems getting full pressure, unless I engage one of the remotes.
Thank you and I hope that you find your brackets
Lennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote SilverBullet Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2020 at 9:23pm
Johnkc
If you have pics and knowledge of how the hydraulics are to be done on a 7045 for a loader I would appreciate it.
Thank you in advance
Lennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2020 at 9:08am
You need a valve for a closed pressure compensation system and a another line. Your valve may have a plug to change it plus a port for the other line.        MACK
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2020 at 10:32am
The valve needs to be closed center load sensing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2020 at 10:58pm
I got a second set for the 7080. I found them with an ad in the farm Bureau Spokesmen. I had a couple of calls from different farmers. There are some out there. Good luck.
