Timing ignition
Wot View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wot Quote  Post ReplyReply Direct Link To This Post Topic: Timing ignition
    Posted: 13 Dec 2019 at 3:01pm
Hi guys,
I have a question in order to fine tune the ignition of an A / 20-45 engine.
The repair manual says: SPARK on flywheel indicating the point where contact points begin to open for nr 1. Is this while cranking the engine or with engine running?
Where should SPARK or CENTER on the flyweel need to stand; is it in center of the gap? Or is there a point to line it with?
Thanks!
Edited by Wot - 13 Dec 2019 at 3:04pm
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2019 at 4:07pm
"Center" always mean when cylinder #1 is at Top Dead Center on the power stroke.
On other Allis tractors (I hedge because I have never dealt with your model) "Spark" would mean when the plug should fire when the engine is running at normal speed, some degrees before the piston reaches TDC.
1951 B
MattLF9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2019 at 7:32pm
I assume it's static timing.
Doubt they had timing lights back then but I could be wrong.
A little CQB never hurt anybody.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2019 at 7:38pm
Sure they did, they used kerosene!LOLLOLLOL
I'm thinking you are bringing up to TDC on cylinder one by hand, not running or cranking.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2019 at 7:42pm
Yes when the engine is just ready to fire #1 you'll want the rotor to be pointing at #1 in the dist. cap. which is about 1:30. You should be close enough to start and run. If you have 12V timing light just power it up with a 12V batt. sitting close by. Hope this helps.      Leon
