816 Backhoe
acjwb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acjwb Quote  Post ReplyReply Direct Link To This Post Topic: 816 Backhoe
    Posted: 16 Aug 2010 at 1:58pm
I am looking at a 816B Allis Chalmers backhoe.  Were there any common problems with this model and what should I check out on this machine??
Thank You
Joe
Dave A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave A Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2010 at 2:47pm
frount axial pivot points. Is the hoe tight . Rear valve bank leaks. If the engin is high in hours look for head leaks. Altenators aren't real durable. Make sure the shuttle does not slip a lot. Drive it down the road with the cab doors open listen for rear end noises. Look for cracks  where the loader attaches to the frame and make sure the out riggers don't leak oil.  Check the fluids for signs be burnt. Check the engin oil for anti freeze. Run it up to full RPM. If it misses, might be a injector pump or injector problem. Watch the smoke comming out of the stack if it is white there might be low compresion or a cyliner leak. ( some of the guys on this site might be better help with the exhust color better than I can). Hours and opertors that use the shuttle as a brake are the machines worst enemy. Gave $5300  for the one, I own. Before I bought it,  it had a new transmision, rebuilt motor, new rearend, One side plantary replaced. and a few altenators. Has been a good starting machine with lots of power. But the waight (16K) and not being FWD causes it to get stuck easly in sand (If diggin down) when when using the loader.
Play the game for more than you can afford to lose... only then will you learn the game.
Winston Churchill
america View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote america Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2015 at 6:31pm
Have a 816B, 1982, bucket and back hoe, new hoses, fittings, fuel lines,
good body, tires, power, best looking 1982 816B I have seen, been in
side for the past 25 years. acquired it for $12,500. It has been my
back yard toy.
This page was generated in 0.410 seconds.
