New WD Owner - Where does the Oil Go?
hardwood61 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hardwood61 Quote  Post ReplyReply Direct Link To This Post Topic: New WD Owner - Where does the Oil Go?
    Posted: 16 Aug 2010 at 1:07pm
I just purchased a WD with a WD45 engine in it (Power Crater) - I ordered a manual but it has not yet arrived and I need to do an oil change before I leave town with it.  I tried to do a search but could not find anything about it - I suppose it may be obvious to everyone but dang I don't have a clue other that the cap buy the distributor ... is that it?  Also I cannot find anything about oil capacity - every place I look that has engine specs has the oil capacity field left blank??
Thanks
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2010 at 1:10pm
Yes that is the cap to add oil to the engine.   I don't recall how much but put in 4 quarts and check oil level and go from there.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2010 at 4:32pm
6 Qts
Post Options Post Options   Thanks (0) Thanks(0)   Quote hardwood61 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2010 at 8:47am
Got it!
Thanks Guys!
ac45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2010 at 10:06am
Also check differential , transmission and hydraulic, all 3 are different plugs located  below and around the foot clutch pedal area, Just as well check final drives to0, there is a plug on the inside of each pan fill till it runs out
Post Options Post Options   Thanks (0) Thanks(0)   Quote hardwood61 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2010 at 10:20am
What should a guy use for lubricant ... 90w gear oil or?
