D 17 Oil Pressure
Tyee II View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tyee II Quote  Post ReplyReply Direct Link To This Post Topic: D 17 Oil Pressure
    Posted: 16 Aug 2010 at 11:51am
I recently changed oil and filter in my Series 3 D 17 Gas and the oil pressure is showing high on the guage ( pegged to the right ) I used a NAPA 1515 filter which is what the book calls for and I believe these are a WIX filter.  Doe s anyone on here have any experience with this ? Is there a particular filter brand that is preferred for these tractors ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2010 at 12:26pm
If it is an "Allis-Chalmers" OEM gauge, ..pegged to the right is very normal.....only time it will be less than that is with hot eng oil and engine idling.
skip(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skip(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2010 at 10:36pm
is it the original gauge? i replaced mine with another that was described as being for a d17, but after seeing the same thing and asking, i found out that there are atleast 2 different gauges, 0-30lb and 0-90lb....something along those lines. don't know if that's the case or not....just thought i'd throw it out there.
