Whats the deal with the 8000 line?
twinsonfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote twinsonfarm Quote  Post ReplyReply Direct Link To This Post Topic: Whats the deal with the 8000 line?
    Posted: 08 Dec 2019 at 12:31pm
What is the deal with the 8000 line of Allis tractors?  They all seem to be lower HP than their 7000 series counterparts.  Up until this point, HP always increased into the newer models?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2019 at 4:38pm
where did you get your,info ?
Edited by DougG - 09 Dec 2019 at 8:06am
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2019 at 4:46pm
I think he might be talking about, in example, the 7060 having 160 hp, but the 8050 having 150. Same with 7080 at 180 and 8070 at 170.
I think he may be asking why did they not go from 7060 to 8060 and 7080 to 8080 or bigger.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2019 at 5:23pm
FWA caused engines to work much harder (because tractor was glued to the ground), so HP was de-rated to try and keep decent engine life.
Post Options Post Options   Thanks (0) Thanks(0)   Quote twinsonfarm Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2019 at 6:00pm
Yup, that's how I should of worded it.  Thank you.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2019 at 6:18pm
They had enough issues keeping the 7080 and 7580 motors together backing things off may be prudent.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2019 at 6:47pm
They kinda re-aligned the hp ratings, in anticipation for a new 200 hp 8095. The 426 was a great engine, but really should have been made as a 466 cid engine for the 160+ hp tractors I feel. The 516 was just too big, old, and heavy, not to mention expensive, for a wheel tractor. It is still surprising they used them in the N7's.
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2019 at 8:17am
In the 8000 they put in the heavier rods which helped.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2019 at 9:05am
The connecting rod thing was two-fold. They wanted a larger diameter piston pin. That meant changing the piston from 4-rings to 3-rings to keep the overall height the same. The piston cooling was then run up thru a passage drilled in the beam of the rod itself. I assume this type of piston cooling was a little better and maybe helped with oil consumption ??  You'd think the new rod was a little stronger as well, but I can't say I ever had an old rod fail.
rieg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rieg Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2019 at 8:02pm
Every 426 that I have rebuilt seemed that its limiting factor to life span was the rod bearings. Not saying that there aren't other failures but the rod bearings have always been wore out. I have a recently acquired an 8050 that has over 7000 hours and supposedly never been apart, and it looks it. I am interested to see what those rod bearing look like. Regardless I really like the 426.
rieg
fourthgeneration View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fourthgeneration Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2019 at 10:18pm
Just better. Evolution if you will. I like that it was never intended to be an open station. Things are just improved over everything that can before it.
Edited by fourthgeneration - 09 Dec 2019 at 10:21pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2019 at 8:23am
When you look at those 8050 rod bearing shells, the date the brg was built is usually stamped on the backside.
This page was generated in 0.087 seconds.
