Ac 2000 plow
Jcfarmboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jcfarmboy Quote  Post ReplyReply Direct Link To This Post Topic: Ac 2000 plow
    Posted: 08 Dec 2019 at 9:33am
Hey everyone!
First post and am trying to figure out the site still.
Anyways, I'm running an 2000 plow 4 furrow and wondering since it has bolt together frame (front and rear) if I'm able to put another few furrows on it.
I was able to find my father's allis 7030 tractor and get her back to working condition for most part, so horsepower isn't an issue.
Looking for the wisdom on here!
Thanks
Jeff
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2019 at 9:56am
You Can Add On The Rear You Will A Need Tube Extension And Extra Bottom
only AC orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2019 at 5:03pm
Yes, Allis made the "2000" plows so bottoms could be added - I had a 3 bottom with a 1 bottom extension many years ago. So that the plow turns dirt even, you will need to find a bottom (moldboard) that matches what you presently have.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jcfarmboy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2019 at 7:43pm
Ok thanks guys! I will hunt down some parts!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2019 at 7:46pm
Welcome to the forum. What other orange do you have
Edited by Mikez - 08 Dec 2019 at 7:46pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jcfarmboy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2019 at 7:51pm
Thanks Mikez,
Just the 2000 plow and the 7030(7060 Injector pump installed and timing corrected) tractor.   Rest of my fleet are Farmalls from grandfather and great uncle. Trying to keep as much from the family farms as possible.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2019 at 8:59pm
There is a plow theme on the knowledge forum with some information on the 2000 plow. The hitch is versatile enough I took off the front bottom and was able to line up the second bottom with the tractor tire in the plow trench. 4-18 proved to be too much plow for my gas 4020. It had enough power to pull but in sticky ground the front wheels rose up way off the ground.
Gerald J.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2019 at 9:43pm
Gerald J.
I had that problem once. I discovered if I didn't lower it it pulled fine!LOL
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2019 at 3:25pm
You may already know, but the AC 2000 plows had a few options.
What is your plows measurements?
- 4-14”?
- 4-16”?
- 4-18”?
Is your 2000 an early 28” or later 32” clearance height?
Which bottom numbers does it have 387, 392?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jcfarmboy Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2019 at 7:27pm
It's a 4-18.
It might have been drilled to except 387 drop hole shares.
It very well could be the 5 hole 392. As it has small bracket to take fifth bolt hole.
It has the spring cam reset but have a line on a 7 furrow hydro reset that I might trade up to
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2019 at 4:10pm
It's a 4-18.
Yes, I agree. You may have a better time of it to just find a plow setup to your liking. Plow setup options can be numerous. Is your 4-18 an early(28”~71cm) or later(32” ~81.3cm)? If you’re not sure, you can measure the inches(cm) from leading(bottom) edge of plow share to bottom edge of monobeam square tube. If you decide to find a replacement plow, ask or look for the later 32” type. It does excellent in heavier crop residues like corn stalks.
Dan Hauter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan Hauter Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2019 at 4:46pm
Welcome to the Forum!  There are a lot of guys on the Forum with a lot of knowledge.  Enjoy!
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2019 at 9:05am
You're planning to pull 7 bottoms with a 7030?  Well.....good luck.
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2019 at 9:14am
Would not recommend 7 for a 7030 as they are getting old but I pulled 7 with mine for 10 years when I got it new, soil type makes a huge difference.       this was a 16 inch IH plow.
Edited by jiminnd - 11 Dec 2019 at 4:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jcfarmboy Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2019 at 12:48pm
Hey tbone,
95% of my field I could pull 10 furrows but the 7 I am looking at can drop the last furrow to make it a 6.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2019 at 1:34pm
Well, that's good farmboy.  I had a 2000 plow years back, and it was the nicest pulling nicest dirt turning plow I've ever pulled.  So, if it could be done, that'd be the plow to do it.
I can barely pull 6 with my 7045 on 75% of my ground, and there's fields where I wouldn't dream of trying...
Like I said, good luck, I didn't mean it negatively.
BTW, 7 bottoms of what, 18's also or 16's?  Makes more difference than most people think.
Edited by Tbone95 - 11 Dec 2019 at 1:36pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2019 at 7:29pm
Hey tbone,
Just wondering if you get your 7 bottom plow?
This page was generated in 0.311 seconds.
