D10 D12 hyd controls leak?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: D10 D12 hyd controls leak?
    Posted: 15 Aug 2010 at 7:27pm
What would cause the valve to leak out the back assembly when lift is raised? Are parts available to rebuild a valve assembly? Thanks Tracy Martin
Edited by Tracy Martin TN - 15 Aug 2010 at 7:30pm
Joe/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe/NC Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2010 at 8:48pm
Tracy, I know you are pretty good mechanic on the AC tractors, but have you checked to see if it is just loose? Sometimes the simple things get overlooked.  Also, check your messages.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2010 at 10:04pm
Joe, There are leaks that are loose. This one seems internal to leak out the little weep hole in end of plunger assembly.A couple of lines have seen better days. Thought someone may have already been down this road. Thanks Tracy Martin
Larry Miller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry Miller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2010 at 10:08pm
Tracy - I think there is a small hole in the back of that assembly to avoid vacuum or pressure.  O rings will leak and move oil out that hole. Short answer - O ring replacement. Be careful and clean - springs and small balls will shoot out if you just pull the assembly. Now I put a shop rag over it when pulling out of casting after learning that lesson.
I used to be young and stupid, now I am not young anymore.
Cary(KY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cary(KY) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2010 at 6:55am
Mine had that same leak and replacing the o-rings internally fixed it.
Cary
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2010 at 8:12am
Tracy thinks for opening the subject.
I have a D-10 series III with 3 point. The 3 point will hot lift. The remounts work.
Anyone worked on one of these?
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2010 at 8:54am
Dusty, Just trying to work out some kinks. Thanks also. Tracy Martin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe/NC Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2010 at 3:26pm
Tracy, I remember Jim telling me about the springs and balls flying everywhere too. The book shows them in the cut-away.
