D17 crankshaft oil seals
djake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djake Quote  Post ReplyReply Direct Link To This Post Topic: D17 crankshaft oil seals
    Posted: 02 Dec 2019 at 3:39pm
I have a D17 Series 1 with leaky front and rear oil seals. Do I have to pull the engine to change them
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2019 at 5:17pm
djake,
 My opinion would be, Yes, Its the right way to do this job correctly. You will need to do a couple other things while your in there too! At least that's how it works for most of us.
Welcome to the forum!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2019 at 8:07pm
Yes it has to come out for the rear seal.       MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2019 at 8:36pm
You have to pull rear main cap to replace seal if you do it right. Don't leave the F gaskets out when going back together....
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2019 at 6:00am
Before you attempt the change, watch Don Bradley's video.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2019 at 6:58am
It has been my experience that on an old Pre-full flow oil filter D-17 gas engine, when they are leaking at the rear and front seals, 50% of the time they need the crankshaft reground undersized and new main bearings to tighten things up.
