D-17 Steering Wheel Removal
CORY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CORY Quote  Post ReplyReply Direct Link To This Post Topic: D-17 Steering Wheel Removal
    Posted: 15 Aug 2010 at 5:03pm
What is the best was to remove a steering wheel on a D 17 Series II.  I took the nameplate off and the nut loose, tried a three jaw puller but didn't have any luck.  Any help would be appreciated.
FredW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FredW Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2010 at 5:44pm
Had some luck with holding wheel up and tapping the nut firmly with a mallot or hammer if you can hit it square. I should have said first put the nut back on and leave a loose but on far enuf so as not to ruin thread. If that done work I take a small grinder with a fine cutoff blade and start making pieces. Fred
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2010 at 6:49pm
If you are trying to save the steering wheel, unfortnately AC didn't make that hardly possible. I'd suggest you drill two or maybe three (you decide) 1/4" holes in the hub and thread them to 1/4" NC and get a steering wheel puller hooked in there and maybe even smack the end of the puller with a hammer and/or use a little torch heat while you have pressure on it. This should be doable but will take some patience getting the holes drilled properly and threaded. Good luck.
john n/il. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john n/il. Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2010 at 7:41pm
I just used an air chisel from the back side and it came right off.Are you using the old one.I put a new one back on.
NICKMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NICKMI Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2010 at 9:25pm
mine seems to be perma rusted on and the nut wont turn whats the best way to remove it and not damage the threads ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2010 at 6:31am
Split the nut with a very sharp chisel  and rethread the shaft after removal.
gcalent View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gcalent Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2010 at 8:50am
I`m with Fred, if all fails, the grinder and a cutoff wheel is the best bet, take your time and you won`t hurt the shaft at all.
Pullin With AC
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2010 at 8:37pm
Here is the way I save my D series wheels. I take a 3 jaw puller, remove the jaws, take small link chain to wrap around the wheel spokes and bolt in place of jaws. But before that wrap duct tape several wraps around spokes to protect the wheel spokes. It will come off and not hurt the wheel.  Dave.
