Gasket adhesive |
ACinSC
Joined: 16 Dec 2015 Location: South Carolina Points: 3252 |
Topic: Gasket adhesivePosted: 25 Nov 2019 at 2:44pm |
I used Indian Head shellac when I put the hydraulic oil pan on the D 15 . It didn't hold the gasket as well as I'd hoped . Maybe because it's old, I dunno . Just wondered what you fellas use ? Thanks
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4077 |
Posted: 25 Nov 2019 at 2:52pm |
brush on high tack [permatex brand] if i need glue one on a part before asssembly real sticky and sets fast,
MattLF9
Joined: 27 Nov 2009 Location: Minnesota Points: 187 |
Posted: 25 Nov 2019 at 2:56pm |
CNH makes a gasket glue that works amazingly well.
I can't remember the name of it but the Case mechanics call it "calf snot" |
A little CQB never hurt anybody.
NomoreJohnDeere
Joined: 24 Jul 2017 Location: Missouri Ozarks Points: 308 |
Posted: 25 Nov 2019 at 3:00pm |
was the surface clean?
HD3
200 10and20
Joined: 20 Jun 2019 Location: Tim Buk Tu Points: 217 |
Posted: 25 Nov 2019 at 3:08pm |
Get the best Copper Coat. Costs more but it's more than worth it. Make sure surface is clean and free of oil.
ACinSC
Posted: 25 Nov 2019 at 3:12pm |
Yeah I'd cleaned the pan well and even wiped it off with alcohol . Thanks
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55282 |
Posted: 25 Nov 2019 at 5:49pm |
lay the pan on a piece of plywood, mark and drill all holes. then place gasket on plywood, and smear the top surface with blue goo. (blue silicone) Go lightly with the blue goo, you really don't want any squeeze out... place pan on top, and put all bolts through holes, to align. If you have longer bolts, to go through the pan and plywood, use them, and tighten them down till everything is flat. You really don't want to over torque these. If you don't have longer bolts, clamp the pan to the board, or weight down the pan. This way the gasket stays with the pan, to make assembly easier...
Dakota Dave
Posted: 25 Nov 2019 at 5:50pm |
Permeated aviation gasket cement
ACinSC
Posted: 25 Nov 2019 at 7:03pm |
Thanks guys !!
DougG
Posted: 25 Nov 2019 at 7:10pm |
Copper Coats one of the least desirable,, Hi Tack is the good stuff,,
m16ty
Posted: 25 Nov 2019 at 8:20pm |
I always Use Indian Head and have had zero problems when the directions are followed. You can't hardly get it back apart after it has set up.
As a side note they now call it "lion". I guess "Indian Head" was too politically incorrect.
MACK
Posted: 25 Nov 2019 at 8:57pm |
Hi Tack is the best. Copper Coat works better for antiseze than it does for gasket sealer.
festus51
Joined: 26 Mar 2017 Location: Osage City, KS Points: 1644 |
Posted: 25 Nov 2019 at 9:13pm |
An fashion way to keep gasket in place with pan is to use string and tie the gasket in several places. When bolting it up place bolts and start them into block. Once you have several bolts in place cut string and pull out one at a time as start bolt in the string hole. This is an old mechanic trick from the 50's and 60's This is with an in frame overhaul.
Edited by festus51 - 25 Nov 2019 at 9:14pm |
We the unwilling Led by the unqualified Doing the impossible for the Ungrateful
200 10and20
Posted: 26 Nov 2019 at 4:26am |
Edited by 200 10and20 - 26 Nov 2019 at 4:29am |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35678 |
Posted: 26 Nov 2019 at 4:37am |
What many refer to as Calf Snot we also called Gorilla Snot in the truck industry, was a contact adhesive slight yellowish in color applied to both the gasket and the part to attach to. We used it on oil pan gaskets on the large engines to get them to Stay where we put them, almost took a grinder or sanding discs to get back off after a few months.
oldways
Posted: 26 Nov 2019 at 10:08pm |
I use Indian Head myself. Never have a problem unless it's really old. Gotta let it tack up a little before install. Lion is a different brand.
ACinSC
Posted: 27 Nov 2019 at 9:59am |
Yeah Lee , I think my Indian Head was just too old . I threw it away . I'll get a new bottle for next time . Thanks for all the replies .
NEVER green
Posted: 28 Nov 2019 at 9:28am |
3M weather strip and gasket adhesive, love it. |
2-8050 1-7080 6080 D-19 modelE & A 7040 R50
ocharry
Posted: 28 Nov 2019 at 10:40am |
permatex aviation ,,,,,never had a leak ,,,but its a pain to get off if you have to,,,,but it will take that over leaks,,,any day
ocharry
JayIN
Posted: 28 Nov 2019 at 7:08pm |
Boss Man
Joined: 03 Mar 2018 Location: Greenleaf, WI Points: 617 |
Posted: 29 Nov 2019 at 11:03am |
3M weather strip and gasket adhesive is what I use.
nickia
Joined: 11 Sep 2009 Location: alden iowa Points: 793 |
Posted: 29 Nov 2019 at 5:51pm |
3m weatherstrip adhesive for oil pan gaskets
and aluminum paint for the head gasket! |
