Diesel Gelling
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: Diesel Gelling
    Posted: 23 Nov 2019 at 5:12pm
What temperature does #2 diesel start "gelling"? What would be a ratio of kerosene/diesel to prevent gelling? I've read the bottles of "additives", but they claim the "mix time" needs to take place above 48-50 degrees, that's not going to happen this fall for us anymore Cry
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2019 at 5:39pm
It depends, is it premium #2 fuel or old fashioned #2? Typical old #2 can start gelling around 32 degrees. Premium can start between 20 and 30 °. It depends on wind chill. This time of year anyone north of the southern Iowa border should be running a minimum of 50% #2 and 50% #1. After Dec 1st if its going to get below zero and stay there a 75% #1 and 25% #2 blend may be necessary. Some of my customers that ran large cattle or hog feeding operations ran straight #1 after Dec 1st till Feb 27th. Their diesels had to run. I have been out along the road changing filters and adding #1 fuel to trucks and tractors at all hours of the day. Every one of them said "But I pored the antijell additive in the tank".
Edited by HD6GTOM - 23 Nov 2019 at 5:44pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2019 at 5:47pm
All I know is that it's delivered to the farm via the local CO-OP, has been for years but have NEVER had concerns about gelling because "normally" the harvest/ fall tillage has been done 5 weeks ago Unhappy
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2019 at 6:06pm
I run 30% #1 with power service down to -15f then 50% with power service when colder. Never have trouble.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2019 at 7:53pm
Best way to keep it from gelling, is a clean, new filter, and some anti gelling elixer, put in every tankful of fuel, after the frost date, in your area.  A filter heated by a bypass loop of engine coolant, is a nice option, too...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2019 at 9:04pm
Not an acceptable heater!
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2019 at 9:58pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2019 at 10:00pm
Check with your fuel supplier. They should be able to tell you if and when they started having winter blend and the ratio. If you got a bulk delivery they should be able to give you the same info about your last delivery.
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2019 at 7:42am
Wind chill is not a factor! It might cool off more quickly in a wind, but it doesn’t go below the ambient air temperature.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2019 at 7:59am
I've serviced home furnaces in the past, and many years ago many of them were oil furnaces. I've seen the fuel jell in some of them.
bill2260 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bill2260 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2019 at 8:49am
When I use to grind feed with 185 on a single diget day after being plugged in couple tractor would start immediately and run fine in shed.   Hook to grinder and back up to oats bin and as soon as I would get off tractor it would shut offf. Fuel gelled up. I finally put some insulation around sediment bowl to keep wind offf. No more problem
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2019 at 10:36pm
I will differ with you guys that say wind chill is not a factor.   I Have been out with the fuel truck when it is zero out and the wind blowing out of the north at 30'-40 mph. Filters jelled up. Put on new filters and fill tank with #1 fuel. I picked up a whole lot of new customers this way, why because my competition believed wind chill does not impact fuel jelling. They had winterized their customers fuel at 25% #1 and 75% #2. Blend it like my years of experince says and you wont have problems.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2019 at 10:53pm
The temperature due to wind chill cannot go below the air temperature. But Exposed, it will cool off more rapidly down to the air temp.
Think about it. Why wouldn’t every radiator freeze solid due to wind chill effects if that were the case?
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2019 at 6:32am
Tom, I hear you, but I gotta side with tramway on this.  I read your story here, and 0 is damn cold, and being out servicing a truck on a night like that with a 40mph wind makes for a memorable night.  But, at 0 degrees, that fuel would be easily ready to gel, the whole tank of fuel would be cold and not getting heat from anywhere to counteract going down the highway.  Windchill makes it get cold much more quickly, but not colder.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2019 at 7:52am
All the wind chill does is mean the wind is blowing harder so it blows away any engine heat you're trying to preserve to keep filter on side of engine or transmission warmer. Wind affects it, not the wind chill factor though. Essentially there's no warm place to hide lol!
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2019 at 8:03am
Wink  I thought that wind chill thing is something that was on a physics test in high school.
I am with, you cannot get it colder than the ambient air temp, gang.
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2019 at 10:46am
WIND CHILL ONLY EFFECTS THE FLESH.
SOURCE: THE INTERNET
The temperature of windless air that would have the same effect on exposed human skin as a particular combination of wind speed and air temperature. As the wind blows faster, heat is lost more quickly from exposed skin, making a person feel colder even though the air temperature remains the same. Also called chill factor
THIS IS WHAT I FOUND ON LINE.
32 degrees
Diesel fuel gelling happens when the paraffin usually present in diesel starts to solidify when the temperature drops. At 32 degrees, the wax in liquid form willcrystallize and leave the fuel tank clouded. At 10-15 degrees, it will finally start to geland clog the tank and fuel filters.Dec 14, 2013
Edited by Acdiesel - 25 Nov 2019 at 10:49am
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2019 at 10:53am
Heat flow has a direction, and temperature difference is the driving force (analogous to the voltage from a battery)  How quickly something changes temperature depends on a few things, like mass, contact area, circulation conditions, etc.  But with no temp difference, no  change in temp.
Heat flows from warm to cold.  You as a living being trying to stay warm, technically feel the loss of heat rather than cold.  More wind removes the heat from you faster, and since your metabolism is trying to keep you warm, you feel colder.  But if you keel over dead, lay there and get cold, once you've reached the air temp, can't get any colder.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2019 at 11:36am
So, how does "colder then a well drillers azz" fit into the picture?
Allis Express participant
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2019 at 2:22pm
That John would be done very carefully. Wink Thumbs Up
m16ty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote m16ty Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2019 at 8:33pm
Wind chill only effects things that generate heat or have latent heat.
On things that generate heat, as in the human body or circulating warm fuel in a engine, wind chill can remove heat faster than the thing can generate it.
On things with latent heat, as in a tractor that has been running and shut down, or a tractor parked in a warm shop and brought outside, wind chill can cause the thing to cool off faster that if their was no wind chill.
As has been said, wind chill will never cool anything down below ambient temp. Wind chill is basically a term meteorologist came up with to try and give a indication of how cold it feels to the human body. Even then, the wind chill will never cause your body to go below the ambient temp anyway, you'd be long dead before you ever got that cold.
Post Options Post Options   Thanks (0) Thanks(0)   Quote m16ty Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2019 at 8:37pm
Some scientist argue that there is no such thing as cold, it is just the absence of heat. Everything would be at absolute zero (no heat in it) if we had no matter around us generating heat.
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2019 at 9:50pm
If you have a tractor in a shed plugged in you may have enough heat in the engine area that you would not have a problem with gelling but if you take it outside  the windchill could remove enough heat to gell up just like it removes heat from your body. The other thing is but I don't think Allis engines do it much is they return some warm fuel to the tank but with the wind that would also cool faster.
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2019 at 7:07am
And this is why they should do away with wind chill and heat index. Tell me what the temp and wind is. If I'm not smart enough to figure out its flippin cold then I will advance the human race by dying.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2019 at 7:30am
Yep, agreed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2019 at 7:33am
True.  Kind of splitting hairs to the meaning of windchill and what was meant in various statements, then again that's what usually happens in any discussion.  I wonder though, you have a tractor plugged in, block getting warm, may conduct to the fuel pump and filter some and start up.  But how long has it been how cold and therefore how cold is the fuel in the tank, and tractor starts right up but then even in the shed the cold fuel starts getting up there and it stalls anyway?  Never know for sure.
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2019 at 1:17pm
Hot and cold are really just terms relative to your own perspective. The reality of it is temperature is a matter of energy in sub atomic particles bouncing off one another . The more energy, the faster the subatomic particles move and the warmer the object feels. When two different objects at two different temperatures such as 15 degree air and a warm 180 degree engine block meet one another. The slower moving particles in the air bounce off the faster moving particles of the engine block. Energy gets transferred. The air warms up and the block cools down until they become equal. Think about what happens when you break a racked pool table. The fast moving Q ball knocks the rest of the balls into motion and it almost stops itself. If you were to neglect friction such as inside an atom, They would continue bouncing off one another until they were traveling at the same speed.
I don’t know if I’m adding anything productive to the conversation but there it is. It’s worth what you paid for it.
Edited by wekracer - 26 Nov 2019 at 1:21pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2019 at 1:33pm
I like it wekracer.
So, while we're on scientific stuff that's not productive, here's another one.
Did you know that there is nothing that measures temperature?  You said it exactly, it's a relative concept.  The 0th law of thermodynamics, to paraphrase, says that if 2 systems are in thermal equilibrium with a 3rd system, they're in equilibrium with each other.  In other words, you can only know by comparison.
Now if you're still laughing, thinking I'm an idiot, because you know lots of things that measure temperature, no you don't!  Think about it: Mercury (or other fluid thermometer) measures density, and as the fluid expands or contracts due to it's relative heat content, there's a calibrated scale showing degrees.  Clock spring thermometers measure the expansion of the metallic spring, calibrated to a temp scale.  Thermocouple measures the changing voltage output of a bimetallic junction, calibrated to read temperature.  RTD reacts to the change in resistance due to heat.  Every device reacts to some other phenomenon and is only calibrated to relate a temperature number.
rw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rw Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2019 at 7:17pm
Right
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2019 at 8:08pm
What brand of additive is recommended,Howe's or Lucas?
