Trouble with my D-17 Diesel
Stephen069 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stephen069 Quote  Post ReplyReply Direct Link To This Post Topic: Trouble with my D-17 Diesel
    Posted: 22 Nov 2019 at 12:15pm
after I parked my D17 diesel it acts like the motor is locked up . It’s not the starter or anything electrical. I’m 70 so I’ve been around a few tractors It was running at 50lbs oil pressure when I shut it down and no it wasn’t hot So I’m lost
Edited by Stephen069 - 23 Nov 2019 at 7:19am
Rhoadesy_65 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rhoadesy_65 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2019 at 12:32pm
Make sure you type out your issue in your post, not on the title of your topic.
Farmin' with 1981 7010 PD, 1983 6080, 1983 8010, Gleaner R42 in Darke County OH
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2019 at 2:21pm
He did!  You know, it acts like TH!LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2019 at 3:18pm
The engine is locked....the tire is flat....transmission is stuck in gear.....WHAT!!!!
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2019 at 3:55pm
Total Hell  Thumbs Up
MattLF9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2019 at 4:19pm
This whole topic and replies.....ROFLMFAO!
A little CQB never hurt anybody.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2019 at 5:06pm
Do reply again, we are just poking you as we call it. The guys really do like to help you solve your problems with your Tractor.
BEK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BEK Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2019 at 5:16pm
Does this happen only when you round bale the Hemp?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2019 at 5:16pm
Originally posted by Stephen069 Stephen069 wrote:
Stephen069,
Welcome to the forum! Some of us have used these forums a lot and are pretty comfortable. Many folks here can help you with orange tractor issues too!
My guess is your a 1969 model?:)
MDWilliams338 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MDWilliams338 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2019 at 6:07pm
Got me curious for sure.Drove it where ? And parked? Was the 17 a chariot for a hot date and then died?🤔
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2019 at 9:13pm
I don't feel too bad about giving him grief with a post like that.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2019 at 10:29pm
He parked it In the Castle of Aughhh....
https://www.youtube.com/watch?v=ZlIz0q8aWpA
LOLLOLLOL
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2019 at 6:29am
The New Member Stephen was last on here an hour ago.
I hope he ignores all the B/S posts and comes back.
Stephen
You can 'Edit' your first Post by clicking on 'Options' in upper R/H corner.
Change the 'Subject' to 'Trouble with my D-17 Diesel'.
Then in the Body of the Post describe the problem you are having.
and 'Welcome to the Forum'
Gary
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2019 at 7:34am
He updated his post. Go back to the top to his first post.
If it sits for a while does it start up normally.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2019 at 7:59am
I'm not a diesel guy, but on a gas one sometimes the starter Bendix gear and flywheel get locked up together and nothing will move. If this is the case you pull the starter and check both gears for any problems, if none reassemble. More guys will be on with more ideas for you soon.
And Welcome To The Family Thumbs Up
Edited by chaskaduo - 23 Nov 2019 at 8:01am
lowell66dart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2019 at 8:20am
The diesel D-17 starter is easy to take off, three bolts. Get it off and hook some jumper cables to it to test it to eliminate the starter. While it's off take a prybar and try and move the engine with the flywheel. That should narrow it down a little.
AC 6080 (8030,7060,200,175,D-17HC, 6040,160,6140 all gone) Farmall 1066 & 656 Hi-Clear (for sale), White 2-62 High Clearance, JD 4255 Hi Clear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2019 at 8:46am
Could have violent in a cylinder.        MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stephen069 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2019 at 10:12am
Ok Mack tell me what a violent is I guess I’m getting old because I’m lost
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stephen069 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2019 at 10:44am
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2019 at 11:14am
I swear MACK voice texts some of these....got me guessing too....can't come up with a word that sounds similar to explain "violent"
Just curios when you say it seems locked but assert it's not starter or electrical. How do yo know that? Like others said,I'd pull starter and pry on ring gear to prove it's the engine.
Edited by SteveM C/IL - 23 Nov 2019 at 11:21am
NomoreJohnDeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NomoreJohnDeere Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2019 at 11:18am
Leave the pto on?
water in cylinder?
starter ring gear jammed?
clutch hung up?
HD3
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2019 at 11:40am
Is Mack trying to say vapor lock in a cylinder?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stephen069 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2019 at 12:12pm
Boy does this old man feel like a mule Thanks you guys It was a Rock between the bendix and the ring gear Slap myself for this one
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2019 at 12:23pm
Hey we all go through it sooner or later. Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2019 at 12:50pm
Two good things about it...
1) you FOUND the cause...
2) it was EASY to fix...
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2019 at 2:24pm
Remember, it's always something simple. It's finding out what the problem is that gets complicated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stephen069 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2019 at 2:39pm
No doubt it’s simple and I am so glad. Needed to move some big bales and my little Ford won’t do the job lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2019 at 3:13pm
...and who woulda thought a rock could even end up there?....it's not automatic to say "Did you check the ring gear for a rock?"
Post Options Post Options   Thanks (0) Thanks(0)   Quote MDWilliams338 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2019 at 4:01pm
Glad it worked out for you. There could be a long thread on mishaps and I can attest I’ve had many.One of my best was setting 2 acres of hay on fire about 10 yrs ago from a stuck bottom roller that got grease hot and set the guts of my baler and field on fire before we could get it put out.....and I had a whole highway of spectators 😂
Edited by MDWilliams338 - 23 Nov 2019 at 4:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stephen069 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2019 at 4:51pm
I don’t have a clue how a rock could end up where it did lol
This page was generated in 0.154 seconds.
