220 fuel injection lines
CALEBnOK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CALEBnOK Quote  Post ReplyReply Direct Link To This Post Topic: 220 fuel injection lines
    Posted: 21 Nov 2019 at 7:49am
I pulled the pump off my 220 to have it over hauled. Someone at one time removed all the clamps that seperate the lines and has over time allowed the lines to rub through each other. Of they've been grazed multiple time and #2 is homemade. Are injection lines an agco only deal or is there an alternate source.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2019 at 1:23pm
Any diesel shop can get them - make them , got some from Capital diesel for 300 bucks a few years ago,
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2019 at 8:10pm
5-6 yrs ago could get from agco bout same price as diesel shop
BKarpel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BKarpel Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2019 at 9:41am
I had Scheid Diesel in Effingham Il make a set about 4 years ago. Was putting larger lines on a 210 for pulling. They used my stock set for a pattern. Every thing matched up and looked just like factory.
Beirnesy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beirnesy Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2019 at 8:37pm
My roosa needs a overhaul on my 220,  Do i need to completely remove the lines to remove the pump or with the lines  unbolted from the pump, can i wiggle the pump off.
Edited by Beirnesy - 22 Nov 2019 at 8:39pm
1969 220,1967 190DXT,1968 190DXT, LGT's 710,,716
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2019 at 9:09pm
I'm not sure you can leave any on. Think they're in the way removing pump(pulling it rearward). I know I always remove them all. It's not as bad as you may think. They can be a little tricky getting them positioned right installing but it's NOT THAT HARD!!!!
If you are capable of pulling pump you should be able to fiddle with the lines.
Edited by SteveM C/IL - 22 Nov 2019 at 9:11pm
festus51 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote festus51 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2019 at 9:36pm
I took my pump off while leaving the lines connected to the injectors.   Wiggle a little but it will come off.
We the unwilling Led by the unqualified Doing the impossible for the Ungrateful
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2019 at 10:52am
If you do remove all the lines, make sure to TAKE PHOTOS of the lines.  Take the photos from various angles.  Also, it is advisable to number the lines.
I always take photos before I disassemble anything.
Photos are a great reference, when you are reassembling.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2019 at 10:53am
ALWAYS use NEW washers for the banjo fittings.  This will drastically reduce the chance of a leak.
