Balancing M2 chopper
OhKen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OhKen Quote  Post ReplyReply Direct Link To This Post Topic: Balancing M2 chopper
    Posted: 18 Nov 2019 at 10:24pm
Put new bearings in the chopper . While we were there , we replaced the knives that had already been turned once and turned the ones that had not been turned . What made me scratch my head tho was the uneven number of knives . 2 rows had 8 knives and 1 row had 9 . How does that balance ? I assume on one end or the other , there is a counterweight to balance the odd knife . Can anybody shed light on how they balanced with that odd number ?
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2019 at 6:19am
You replace the knives in sets of 3 to keep it in balance. If you don't, you will shake it apart. I have never counted the knives on my L2 but the chopper was shook up pretty good and vibrated bad. I welded and reinforced and when I had a bad knife I replaced 3 knives as they went around no matter if the other knives looked good or not.... they have to be replaced in sets of 3....... smoothed it right out.
Edited by Lonn - 19 Nov 2019 at 6:21am
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2019 at 6:31am
Don't know what's going on there but should be 3 at every position.
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2019 at 6:35am
If you replaced "some" of the knives with new and just "turned" others, the difference in weight of the knives alone will throw it out of balance I would think?? We replaced in sets of 3 also as Lonn said.
Post Options Post Options   Thanks (0) Thanks(0)   Quote OhKen Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2019 at 9:02am
Guys your missing or I'm á not doing a good job of explaining my point . Choppers have 3 rows of knives . That is why you always replace 1 in each row to keep it in balance. Knives always come in bags of 3 . Have replaced knives in L and F and never ran into this before . This chopper and I assume all M's are this way , It has 2 rows with 8 knives and 1 row with 9 knives . How did they get the chopper to balance with I row with an extra knife ? The chopper is balanced it runs smooth as silk . Dr Allis could you enlighten me ?
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2019 at 9:53am
I’ve never been around an M but I know The F and Ls have the same number on each row
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2019 at 9:59am
Haven't done any chopper work in 20+ yrs. It is what it is. If it runs smooooooth no worries.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2019 at 9:14pm
I think the two rows with 8 have some weights in them.      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2019 at 9:25pm
Well I'm confused. Parts book says use 9 sets of 3 to do complete replacement. Straight M series. First design M2 says use 11 sets....second design just says 3 hammers per set. Don't say how many sets to use.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2019 at 5:10pm
I looked up his hammer # on the parts book and I found that the hammers are sold in 3's, but the bushings that go in them are a 25 pack ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote OhKen Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2019 at 8:36am
1 row has an extra knife . All chopper knives are sold in 3's that is the way it has always been . It takes 25 knives and you must buy 27 . I'm going to go with Dr Allis's advice . I don't know how the Gleaner engineers got it to balance , but they did . It runs smooth as silk . Somewhere in the rotor there is provision to counter balance the odd knife .
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2019 at 8:21pm
Like I said earlier, two rows have weights in them.        MACK
