WD Allis Camshaft trouble
clayman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote clayman Quote  Post ReplyReply Direct Link To This Post Topic: WD Allis Camshaft trouble
    Posted: 16 Nov 2019 at 11:12am
Hi, I'm new to this forum. I currently own 2- WD's, a "B" and a D12. I am trying to remove the camshaft from my WD as the gear teeth are gone that drive the oil pump. I have everything removed but the cam. It moves out about 3/8" and stops? Is there any secret clips that im missing or can i just maybe slide hammer it out?
Any help would be greatly appreciated
pirlbeck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pirlbeck Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2019 at 2:21pm
Do you have the oil pump removed and is the block inverted or are you holding the 8 cam followers (lifters) away from the cam with magnets or dowels? You should not need a slide hammer to remove the cam.
Post Options Post Options   Thanks (0) Thanks(0)   Quote clayman Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2019 at 2:49pm
Ok im an idiot, my very first lifter had crept down and was catching. i had a crappy little magnet on it and cloths pins on the rest. Im to quick to ask before checking thoroughly.
1 more question though, when i install the magneto housing again does that gear need to be timed with the cam?
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2019 at 5:56pm
You can Download this manual.
Use the Download Button at the top left of page.
I know it says Allis-Chalmers-B  but it has the WD and WD 45 in it to.
HTH
Edited by chaskaduo - 16 Nov 2019 at 5:58pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2019 at 6:22pm
I don't know if there is a mark on the governor gear to time it, but the drive slot for the magneto HAS to be HORIZONTAL, when the engine is at TDC of cylinder 1 compression stroke.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2019 at 9:24pm
clayman,
 Welcome to the forum! Your doing good! I have to ask so many questions and have to do things over all the time. Keep up the good work on the engine. Good luck with your rework! i am stuck int eh 50's on these old WD's!
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2019 at 6:34am
If you are using a distributor, no need to time the governor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote clayman Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2019 at 8:31am
I am using a magneto so maybe i will have to. I guess i need to find a shop manual
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2019 at 8:40am
Speaks about it in the manual I posted for you earlier.
Post Options Post Options   Thanks (0) Thanks(0)   Quote clayman Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2019 at 9:33am
OOPs i missed that manual link. Thanks for posting this will be very helpful
