Allis B engine rebuild
Levibridge95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Levibridge95 Quote  Post ReplyReply Direct Link To This Post Topic: Allis B engine rebuild
    Posted: 12 Nov 2019 at 8:55pm
I accidentally mixed up the lifter rods in my B engine. Is it terribly important to have them matched up perfectly or will they wear themselves in again to the new position?
ryanschott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryanschott Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2019 at 9:02pm
Push rods should make no big deal what spot they are in just have to adjust rocker when all back together. Which you should do even if you had them in the original spots anyway
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2019 at 5:54am
Not to worry! They will be fine. I have always tossed then into a pail, wire wheeled them and washed them in old fashion degreaser called farm gasoline.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Levibridge95 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2019 at 6:21am
Ok. Thanks guys.
