Worm Gear Removal
Jareddrew82 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jareddrew82 Quote  Post ReplyReply Direct Link To This Post Topic: Worm Gear Removal
    Posted: 11 Nov 2019 at 8:18am
I have a WD45 wide front and I’m trying to clean front bolster out due to all the gunk. How do I remove the worm gear? And top bearing? Thanks
Edited by Jareddrew82 - 11 Nov 2019 at 8:22am
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2019 at 8:50am
I think vertical shaft has to come out first, then remove two bolts on bearing cap and remove.          MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jareddrew82 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2019 at 9:14am
Do you have to press the vertical pin out? Mine is very tight. Wanting to make sure I’m not tearing something up getting it apart. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2019 at 10:01pm
Take bolt and setscrew out of bottom and shaft and gear comes out the top.      MACK
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2019 at 7:53am
After you separate the steering shaft, remove the two bolts on the rear of the bolster, you can then rotate the shaft out of the bolster. The rest of the gears and bearings will come out the bottom. All the bolts top and bottom need to come out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jareddrew82 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2019 at 5:16pm
Thanks for all the inputs! I got it
This page was generated in 0.035 seconds.
