New to me WD45
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Topic: New to me WD45
    Posted: 08 Nov 2019 at 6:39pm
I bought a WD45 yesterday that is the nicest one I've ever seen.  It is a one owner tractor that has been carefully used and well looked after.  It's been shedded all its life. The paint is in great shape as are the decals.  It currently has a 12 volt battery that was put in very recently and a 12 volt headlight was added to the right side.  They will soon be gone to be replaced with a 6 volt battery and the proper headlight.  Everything works as it should and the hand clutch has a good snap to it and hardly any wobble on the pivot bushing.  It drives like a new tractor. only thing missing was the lift latches, but I had a good pair here in my parts bin. Price wasn't a steal, but I don't think I overpaid for one this good!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2019 at 6:44pm
A few more pics.  Serial number is 172697 which should make it a '54.  Only downside is the dent in the top of the tank.   I have another tank but the paint probably won't be an exact match.
Edited by Alberta Phil - 08 Nov 2019 at 6:45pm
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2019 at 6:47pm
Sure looks good. Nice that it has wheel weights.
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2019 at 7:07pm
you can make you a bent bar an go in the filler hole an push that dent out' did a few over the years. it works. can do it right on the tractor.
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2019 at 7:19pm
That's a great looking WD45! Good for you, Phil. I hope you enjoy it for many years to come.
WC, CA, D14, WD45
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2019 at 7:34pm
with a WD front end. Still looks nice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2019 at 8:03pm
Phil,
 You did real good! Nice straight tractor! Have fun with it!
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2019 at 8:42pm
Very nice looking original tractor.  You can tell it wasn't used for tillage as the backs of the fenders ain't all crunched up like they are on 98% of all WD/45 tractors!  Those might be the original rear tires too!
garden_guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2019 at 9:46pm
Whew, beautiful looking tractor!
FranksWD45PS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FranksWD45PS Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2019 at 10:19pm
That is a nice WD45. Like the paint on it. Leave it be.
I was lucky also this summer. I found this 1956 WD45 and was the first caller on it. I finally found a 45 in decent shape and it has factory PS, belt pulley and lift arm couplers. Its been repainted and not a show tractor but thats fine with me. I like the aged look. I've been picking away at it, cleaned carb, fuel tank, new plugs, engine oil change and hydraulic oil change. Lift arms have an issue with the pump keeping them in the up position but I'll fix that. Love this old girl. I grew on on a WD. The 45 was my dream tractor to own.
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2019 at 7:48am
The hand crank works well for many of these dents. The generator can be rebuilt as a 12 volt should you decide to keep it as 12 volt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2019 at 8:08am
 There s NOTHING WD about the front end. The 4 bolt wide front didn't come out till the 45 Diesel. It's kinda like saying a curved shifter is a 45 transmission, when they came out on the WD 2 years, and nearly 20,000 tractors before the 45 was built.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2019 at 9:10am
I would think that a little compressed air would fix the dent in the gas tank.
Just turn the gas valve off first.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2019 at 9:27am
Thanks for the comments.  I'm pretty happy with this tractor.  I may install my loader and blade on this one and semi retire the old WD which has been working hard for the last 25 years!
I'll have a go at removing the dent.  After all, my specialty is auto body restoration and repair so no stranger to removing dents!
I'll check out the existing gennie to see if it's OK when I put a new 6V battery back in.  I have a rebuilt gennie on the shelf ready to go if it isn't
All my Allis tractors are still original six volt systems and I usually don't have any starting issues.  The only one that was hard to turn over was my WD with a slightly modified WD45 engine.  That was solved by having Steve at B&B build me a special 6 V starter that spins 'er over like it's on 12 volts!
Edited by Alberta Phil - 09 Nov 2019 at 9:30am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2019 at 6:08pm
Mine is number 175421 so close to that one. Has the same 3 bolt front end. And it is all original.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2019 at 8:41pm
My 1954 has a 3 bolt front axle as well.  Great looking original tractor there.  I would not worry about that dent in the tank.  If that is the worst thing that has happened in its life, it has had a good life compared to many others I've seen!
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2019 at 8:52pm
Good lookin original,, just a little buffing on there and it will shine like a diamond! I have a early '45 that also has a "3 bolt" WFE, it is a dual fuel LP/gasoline
Reindeer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reindeer Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2019 at 9:14pm
Sweet looking machine!
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2019 at 9:31pm
That's a good looking old gal. Only thing I see that might not be original is the light facing the rear, and it might be original, I've just never seen 1 like it. Dads 55 had the little red light there. I always wanted a 45 with a wide front. Father in law had 1 and you did not need power steering on it. I sure hope you have fun with it.
Edited by HD6GTOM - 10 Nov 2019 at 9:36pm
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2019 at 7:13am
According to my 'list' that I keep, the 4 bolt wide front started at serial no. 186413. Think I got that out of Norm's book.
Also on the list; snap-coupler became standard at 151381.
Constant mesh, (WD45) transmission at 127007.
Distributor ignition at 136318.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2019 at 7:42am
When did the foot clutch foot rest get smaller?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2019 at 7:49am
I did not know it changed? I have only seen one type. So Were they very early WD's?
Pictures?
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2019 at 8:34am
I'm sure they are out there but that is the first original snap coupler decal I have seen. This is one good looking orange gal for sure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2019 at 10:03am
I think the fender light was installed by the original owner as a rear work light.  It's mounted where the original small red light was.  I have one of those but don't know if I'll change it over.  I will get rid of the big right headlight which is a 12 volt sealed beam unit on a made up mount, and replace it with an original light.
It didn't show up in my first pics, but the traction booster gauge is there.  Don't know if it works though.  I re-installed the lift latches on the arms as all my equipment is snap coupler.  Just put new springs on them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2019 at 1:13pm
Phil,
Do you have good methods to remove the drive pins in the lift latches if they are broken off?
I think you did real good on this tractor! It is very nice!
Edited by Sugarmaker - 11 Nov 2019 at 6:08pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2019 at 2:04pm
Chris, yes I do.  I just did a couple yesterday on another set of latches.  I place a 1/4 in. flat washer over the broken drive pin and weld thru the washer to the broken pin. Then I weld a 5/16" nut to the washer, again plug welding through the hole in the nut.  Let it cool and then slip a 1/2 in. box end wrench over the nut, wiggle it back and forth a few times 'til you feel it loosen up, then screw it out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2019 at 6:10pm
Phil,
 Thank you! I can see how this may work good. I will try to save another set of these!
acd17toy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd17toy Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2019 at 6:23pm
What happened to  the rear hydraulic outlet, I do not see one?
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2019 at 8:20am
Great tip! Got a bunch of them around here to work on this winter, think I've got 4 sets of springs ready to go.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2019 at 7:58pm
acd17toy. The rear hydraulic outlet and feed tube has been removed and the port on the valve body plugged.  I'll probably re-install one.  I can take one off of one of my parts tractors.
