76 gleaner k cracking kernels
bleeds orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bleeds orange Quote  Post ReplyReply Direct Link To This Post Topic: 76 gleaner k cracking kernels
    Posted: 07 Nov 2019 at 6:34am
Recently purchased this machine sives,concaves and rasp bars are like new. Cylinder slowed all the way down,I raised cylinder clearance up to 3/4". Still cracking kernels.
Help please.
Thanks cory
old farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote old farmer Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2019 at 6:59am
How many concave bars are you using and how wet is the corn?
Post Options Post Options   Thanks (0) Thanks(0)   Quote bleeds orange Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2019 at 7:02am
25%. Not sure on how many concave bars
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2019 at 7:25am
What size pulley are you using on right side of cylinder? How much corn is in return? Are you settling cylinder clearance by gauges on side, or measure?      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2019 at 8:07am
Correct cylinder pulley for corn is 20 inches in diameter and almost rubs on the tailings return tube. Cylinder speed needs to be 500 RPM or less. How fast are you running it ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote bleeds orange Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2019 at 8:48am
Setting cylinder clearance by gauges. Nothing in the tailings return. Cylinder speed is slowed all the way down.   I will check pulley. Bin is free of debris, just cracking kernels is only problem
Thanks cory
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2019 at 10:40am
Unless you have "set" your gauges, I would not trust them
Post Options Post Options   Thanks (0) Thanks(0)   Quote bleeds orange Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2019 at 11:23am
So back to the concave ?. If I have 5 or 6 than removing some will help my cracking situation? How many concave s is acceptable?
Thanks cory
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2019 at 11:54am
Three for corn. One on the door....skip.....concave....skip...….concave.
Edited by DrAllis - 07 Nov 2019 at 11:55am
Post Options Post Options   Thanks (0) Thanks(0)   Quote bleeds orange Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2019 at 5:42pm
I have only 3 conclaves. So I'm in search of a 20" drive shieve.
It has an 8.5" shieve on it now.
Thanks cory
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2019 at 8:54pm
Just paint "Jimmy" on it and call it a day!
Sorry, couldn't help myself!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2019 at 9:13pm
I never run one on door in corn unless I'm in rocks or dozed ground with roots. Corn will beat door latch to death.
If you have the 8.5 pulley, you grinding corn.
I think I have a 20" pulley, will check tomorrow.      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2019 at 10:55pm
you should be able to shell all the corn off 25% cobs with 3 concaves...get below 18 and get by with 2
Post Options Post Options   Thanks (0) Thanks(0)   Quote bleeds orange Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2019 at 5:27am
Ok thanks MACK. Let me know on that pulley.
Thanks to everyone else.
Pete from IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pete from IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2019 at 6:36am
You will need a longer belt also with the bigger pulley.
JimIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2019 at 9:07am
We ran a K in corn for about 15 years.  Great little machine for the job.  I played with it gradually and finally got it dialed in where I liked it. Had a good set of bars, 20" pulley and three of the round concave bars in the places they recommended above. If the corn is wet or has the cob mold you will need to add a standard concave in place of a round concave bar.  Your not going to completely eliminate cracking in todays yields but this setup always worked very well for me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2019 at 8:33pm
No 20" pulley, only a 16.5.       MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2019 at 5:44am
All the F-2's were sold got the 16.5 inch pulley. The slowest it would allow was 500 RPM, which is still plenty fast for corn, but when doing beans you didn't have to change to another size pulley.
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2019 at 2:32pm
OMG Mack, that makes PERFECT sense about the corn/door rasp bar!! May I ask what position of the bars you run in corn ? We have aftermarket wide spaced cylinder bars in the F2 now. Thanks .
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2019 at 7:55pm
Start at second position then 4 for two bars. Book tells you how to space. Every other one. If more are needed for complete threshing they add at the rear on  concave door. I don't have rocks so I run 2 concaves in #2 &#4 in corn and beans.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2019 at 8:18pm
Like SteveM said, but always one on door in beans. There's always a stick or something around the edges.     MACK
JimWenigOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2019 at 9:00pm
For this very reason, I had picked up a 16.5" at the salvage yard some time ago and was going to put it on my K2 to harvest beans this fall since the decal on my combine listed this combination as an option. I found out there was no belt made for putting the 16.5" on the K2, so went back to the 13".
soybreedingboy77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote soybreedingboy77 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2019 at 5:40am
Should be the same belt as the F2
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2019 at 5:20pm
BLEEDS ORANGE, what was your solution to the cracking?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2019 at 9:28pm
I usually pick around 18%. this year it was 21-22. I cracked a bunch of corn. Wonder if that's part of the trouble?
Post Options Post Options   Thanks (0) Thanks(0)   Quote bleeds orange Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2019 at 5:39am
No more cracking of the kernels.   Made sure I had 3 concave bars, which I did. I had to buy a 20" drive pulley for cylinder, and a longer belt of course.
Machine does a nice clean job.
Thanks cory
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2019 at 6:01pm
MACK, I hope your right on the rasp bar placement (none on the door in corn). I removed the door bar and installed bars at #2 and #4 spots. The original setup was door and #3. Dad swore it had always had 3 bars in it Ermm. Never knew that there are provisions for a total of 6 bars in an F2 until I started counting rows of bolts Smile All we need now is the corn to come  off of 29% moisture .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2019 at 6:44pm
Leave it in the field, itll dry down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2019 at 6:55pm
Doug, I'm all for it but dad is working himself into a coranary because all of the BTO'S around him are done Stern Smile . Will be interesting to see how they repair the ruts next spring ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2019 at 9:00pm
Alot of the ruts will freeze out during winter. I hope.     MACK
