CA air filter cleaning
CAPTMARCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAPTMARCO Quote  Post ReplyReply Direct Link To This Post Topic: CA air filter cleaning
    Posted: 06 Nov 2019 at 10:00pm
Folks need some guidance. Took the oil cup off and the filter looks all gummed up. Took the whole filter housing off. Question now is what’s the proper procedure for cleaning the can and internal filter media?
Thanks!
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2019 at 3:41am
I emptied the oil put thecapback on and set the whole assembly up in the parts washer stuck the hose in the top turned it on and let it run. It looked clean to me when I was done.
NE GA Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NE GA Allis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2019 at 3:58am
Not sure if you may be able to just soak and rinse but I did not have any luck with that method. The last time I cleaned one of these filters I took the bottom retainer off and pulled all the screens out. I think there was around 12 screens inside if memory serves me correctly. Soaked the screens in diesel fuel and scrubbed them with a tooth brush til they were clean.
The catch:
-the bottom retainer on the filters I cleaned were soldered on the filter body. Extreme caution and patience are needed or you will have a big fire.
-the filter screens are fairly malleable, you may have to bend them back in shape to get them back in the filter body. They may bend around a little when you are trying to pull them out of the filter and when your cleaning them.
Maybe there is an easier way but that was the most successful cleaning method I have found. It definitely takes patience and time but you will have a clean filter.
Keeping Allis alive with:
2 B’s, 1 C, 6 CA’s, 2 WD’s,
1 WD45, 3 D15D’s, 1 D17
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2019 at 6:31am
Captmarco,
Welcome! Pictures of your CA would be great!
Have never been into a CA but if they are anything like the WD series. Then yes remove the screens from the bottom, soak and clean. Then reinstall. On one I unrolled the screen to make it easier to clean the gunk and debris out.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2019 at 10:14am
The CA shop manual doesn't call for removing the filter elements but does call for daily cleaning and daily replacing the oil on page CA-31 or total manual page 130.
http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf
Gerald J.
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2019 at 10:19am
I took the whole assembly off and let it sit in a bucket of kerosene for about a week.  The kerosene got darker, the filter media got cleaner.  Let it drip and air dry over night, back on the tractor with fresh oil in the cup.
Edited by HoughMade - 07 Nov 2019 at 10:20am
1951 B
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAPTMARCO Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2019 at 1:31pm
Thanks for the replies! It looks like the filter media isn’t removable which is fine. I’ll soak in a bucket of kerosene and re oil. Had some muddy oil water come out of it at first but she’s been in storage for about 5 years so no shock there. Still runs great though- just cleaning her up and getting it tuned up. Thanks again!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAPTMARCO Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2019 at 1:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAPTMARCO Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2019 at 9:19am
Had the air cleaner soaking a while, going to get it dried and painted.  Is there a method to refilling or conditioning the filter media and oil cup?  I'm unsure of how much and of what oil to use.
Thanks!
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2019 at 10:09am
Manual says 1/2 pint motor oil in the lower removable cup. The air flow draws oil up into the filter media to collect the dirt and dust, self conditioning.
Edited by chaskaduo - 27 Nov 2019 at 10:12am
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAPTMARCO Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2019 at 2:55pm
Just regular 30w or 5w30?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAPTMARCO Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2019 at 2:57pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAPTMARCO Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2019 at 2:58pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAPTMARCO Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2019 at 2:59pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2019 at 3:08pm
I don't imagine it matters much in the air filter as long as the oil is full.  I use the same thing as I use inthe tractor.  Rotella 15w40 conventional.
1951 B
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2019 at 8:46am
I went to a tractor show with a guy one time that pulled the oil cup off his WC I think and not only was there no oil in it, it didn't look like there had been any for a while.  He was just beside himself that he forgot to put oil in the cup and beat himself up for 2 days over it.  Couple days after the show he calls me and laughingly tells me that he forgot that he had replaced the metal mesh with a paper filter when he restored the tractor and thus didn't need any oil.  (Don't tell Maddux I told you this)
