7020 tractor |
nick121
Topic: 7020 tractorPosted: 03 Nov 2019 at 8:16am |
Just casually looking for another tractor. Have a 7040 p.d now and had another 7040 last year I sold. So wanting a second tractor to run with the 7040. I'd use the 7040 for tillage etc and the heavy work. Found a 7020 P.S I'm going to take a look at Probably run the 7020 on the light jobs like planting (only 4 row) and drilling beans spraying etc. But The 7020 should be able to pull my 21 massey disc? and a 5 furrow Ih plow pretty well right? I haul my grain in gravity wagons, 500-550 bushels a trip, have some hills. How would the 7020 with the power shift handle it? Be handy to be able to shift easily vs the power director but the 7020 having the 649I will be short on cubes. Just wondering overall what everyone thinks of a 7020, this one has 7700 hours. WAs it under powered with the 301? I'd think it would work great for the lighter jobs and maybe save a bit of fuel? |
soggybottomboy
Silver Level Access
Posted: 03 Nov 2019 at 4:38pm |
Used to have a 7020. At 1500 rpm and under there was no power and the smoke looked like an oil well fire. Over 1500 it had a lot of power. I think lots of tractors are that way anymore. My son's john deere 6430 behaves the same way only it doesn't smoke.
victoryallis
Joined: 15 Apr 2010 Location: Ludington mi Points: 2887 |
Posted: 03 Nov 2019 at 5:27pm |
How does he like the 6430? I’ve been dreaming of one for a bit. |
Joe(TX)
Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
Posted: 03 Nov 2019 at 6:44pm |
Sounds like either the injection pump is turned up too high, bad injectors or you have a turbo problem
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 9001 |
Posted: 03 Nov 2019 at 7:05pm |
Below 1500 no balls sounds pretty standard for a factory setup.
DrAllis
Posted: 03 Nov 2019 at 7:28pm |
You will like a 7020 power shift if everything is right. The transmission allows the RPM's to be where the turbo is spooled up. It will be perfect for the way you want to use it. Keep the weight at 12,000 lbs or less ( no fluid), which is 100 lbs per PTO HP. Remember, it is a tractor that is 40 yrs old. Lots could be wrong with it.
wekracer
Joined: 13 Oct 2009 Location: Tebbetts, MO Points: 1595 |
Posted: 03 Nov 2019 at 7:59pm |
I have an 8010 basically same tractor. I love it for spreading fertilizer brush hogging baling and planting. Some say it’s under powered but with the power shift just drop another gear. I think it’s a really nice big frame tractor with a smaller engine. It’s really fuel efficient compared to a 426. I love mine. Good luck
soggybottomboy
Silver Level Access
Posted: 03 Nov 2019 at 8:49pm |
The 6430 is a very smooth running tractor for a four cylinder, and a handy loader tractor. Of course, it is a much newer tractor too, and also a front wheel assist. Front wheel assist is wonderful on a loader tractor.
CrestonM
Joined: 08 Sep 2014 Location: Oklahoma Points: 8484 |
Posted: 03 Nov 2019 at 9:54pm |
We have a 6420 MFWD and like you said, excellent loader tractor. I really the shuttle shift for loading bales.
WD45Diesel57
Joined: 20 Jul 2010 Location: Varna, Ont. Can Points: 646 |
Posted: 04 Nov 2019 at 7:27am |
if its the 7020 in seaforth I know that tractor quite well, it used to be mine and did all the work to it, sold it couple years ago and I know the fellas that own it and they look after it, if any questions about it and what I did to it feel free to text me 519-860-7437
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
Leon B MO
Joined: 12 Sep 2009 Location: Old Monroe, Mo Points: 2235 |
Posted: 04 Nov 2019 at 7:53am |
We have a PD 7020 and a ps 8010, like them both. If you use it like any other 110 hp tractor, you'll be fine. If your 7040 PD handles the gravity wagons ok, the ps 7020 will too.
Leon B Mo |
7060
Joined: 16 Sep 2009 Location: Missouri Points: 1155 |
Posted: 04 Nov 2019 at 6:46pm |
My 7020 is a PD, but still one of the most used tractors I have. Feels like more tractor than 120hp.
rieg
Posted: 04 Nov 2019 at 7:01pm |
Have had two of them first was a pd 20 speed, taking off with a loaded wagon was not ideal but a good reliable tractor. Traded it in the 80s when deere was offering two times the value or any tractor that wasn't green. Second one came years later when I needed a cab planter tractor it had ps and we loved it very gutsy and snappy. Sold it to buy an 8030 with mfwa. Can't go wrong with the ps great transmission.
rieg
