96 Dodge Stratus poor heating
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: 96 Dodge Stratus poor heating
    Posted: 03 Nov 2019 at 7:50am
My 96 Stratus is having heat issues,, going down the road it has some heat in the car but not comfortable at 20 degrees, sitting in the parking lot idling it heats up great, gets nice and toasty, its full of water/antifreeze, ive reverse flushed out the heater core, newer thermostat- last year, new water pump this spring, heat gauge runs right in the middle , never seen this till now
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2019 at 9:43am
Sounds like a fresh air damper door isn't closing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2019 at 9:50am
Good call there, I turned the knob but really didn't feel resistance , ill check deeper into it, thanks
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2019 at 9:52am
 DITTO ,,on what ole Chask says,,if it is vacuum operated,,the door may be staying open some due to LOW vacuum. Check the supply to it ,,maybe hole in vacuum supply line,,?
DonBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2019 at 5:33pm
Is there an air filter on the fresh air? Most vehicles now have air filters and they are somewhat out of site and out of mind. People forget about them and they can get plugged up with dirt and bugs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2019 at 9:53am
Got the door closed it helped,, but still a little cool, thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2019 at 1:46pm
Maybe back flush your heater core.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2019 at 7:39pm
Gonna try that again , it did help before
This page was generated in 0.539 seconds.
