hydraulic cylinder
acd17toy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd17toy Quote  Post ReplyReply Direct Link To This Post Topic: hydraulic cylinder
    Posted: 02 Nov 2019 at 6:57pm
  Need to replace a bad hydraulic cylinder, will a bigger cylinder give more lifting
  power, without changing the pump pressure?
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2019 at 7:50pm
Yes, same pressure applied to larger area (bigger diameter) will develop more force.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2019 at 11:28pm
Yes lifting capacity will increase but speed will decrease in cycle time .
Take your PSI and flow rate and multiply by sq in of the piston will give you a idea of what you gain or lose .
 Surplus Center might have what you need at the price you can afford for new cylinders .
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2019 at 12:08am
As already said, lifting force will go up but the trade off is that speed of raising & lowering will slow down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd17toy Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2019 at 7:01pm
  Good deal  as the present cylinder is faster than I like, so a bigger cylinder will slow things down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2019 at 3:12pm
NOW what are you foolin around with Jim?  Something fun?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2019 at 4:55pm
hmm.. if there's lots of GPM, it'll raise as fast as the orginal ?
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2019 at 9:38am
Nope.  For a constant flowrate, Velocity is proportional to the cross sectional area.  It's called the continuity equation Q (cu ft/s) = V (ft/s) x A (sq. ft)
Rearrange to suit, and use any units such as ft, inches, meters, doesn't matter as long as you use the same in all three terms.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2019 at 10:34am
well that's a bummer...
I found this...
Cylinder Speed (ft/min)  =  19.25 x flow rate (gpm)  /  area (in²)
which says to me if you can increase flow rate(gpm), it'll go faster.. so bigger hoses would mean it'll go faster ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2019 at 10:57am
I found this...
Yeah, if you increase flowrate, it'll go faster.  We're talking hooking a bigger cylinder up to the same tractor, so the flowrate is virtually the same, so the cylinder will move slower.
Bigger hoses?  No, bigger pump, or in more complicated modern systems, more oil delivered by the pump via it's load/ flow sensing mechanisms, but still, the diameter of the hose would mean hardly anything as far as being less restrictive.  Centrifugal pump feeding a water line, totally different scenario compared to a vane, or gear or other positive displacement type pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2019 at 10:59am
I found this...
In your equation, 19.25 comes from dividing 144 by 7.48.  144 is conversion of square feet to square inches, 7.48 is converting gallons to cubic feet.  It's my equation pre-worked out for you!Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2019 at 11:27am
here's where I borrowed it from...
.. too many equations and numbers for me today...
head hurts from looking at the garbage truck and seeing the can of worms hydraulics on it !
