How to add oil to clutch?
Leop View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leop Quote  Post ReplyReply Direct Link To This Post Topic: How to add oil to clutch?
    Posted: 02 Nov 2019 at 5:43pm
I have an HD6G and have fixed a bad clutch oil circulation pump. Now I want to test it.
But where to add the oil? Are the clutch housing and the aluminum sump tank connected?
What cheap oil can I use in there until I confirm that I don’t have any leaks? What final oil do people use?
Is the oil filtered on the return line? The line that connects under the filter?
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2019 at 8:39pm
The cluch use ATF or 10 sea oil and you should refill on aluminum sump tank
Leop View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leop Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2019 at 2:24am
All I see on the Aluminum tank is a dipstick and the pickup on the operators left side. Is it on the right side of that tank?
Do you happen to know how much fluid it takes? I have not gotten a service manual yet.
Thanks for your help.
Leop View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leop Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2019 at 2:35am
Gemdozer,
Can you tell me what "10 sea oil" is? I searched the Web and found Seaoil the company, but i don't see a product from them with the number 10. Is 10 the weight?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2019 at 4:38am
Try S.A.E 10 Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2019 at 6:09am
If remember you refill by dipstick  and make a mistake yesterday it is S.A.E 10 oil .
Leop View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leop Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2019 at 4:03pm
Okay, so do not use SAE 10 oil, just ATF oil. Right?
Will hydraulic oil work in a pinch, or only ATF?
Leo
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2019 at 5:14pm
Yes you can use sae or atf oil in cluch
This page was generated in 0.250 seconds.
