Loaded 14.9 X 26 tire weight |
Post Reply ![]() |
Author | ||||||
ACinSC ![]() Orange Level ![]() Joined: 16 Dec 2015 Location: South Carolina Points: 3034 |
![]() ![]() ![]() ![]() ![]() Posted: 02 Nov 2019 at 5:40pm |
Anyone know about what they weigh ? Loaded with water . Thanks
Sponsored Links | ||||||
dawntreader74 ![]() Orange Level ![]() ![]() Joined: 28 Oct 2013 Location: Manteno Points: 1770 |
around 650 or more
Would that be apiece ? Thanks
yes;; each wheel an tire'
Ok , I was wrong again . Figured it added about 1,000 lbs total . Thanks
they mite be more' i got a 13.6-28s there around 800 each
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22061 |
Pure water weighs less than calcium chloride. 7 lbs versus 10 pounds of the good stuff. So on 45 gallons per tire that could be 270 lbs difference. I'd speculate tire, tube and rim to be at least 250 lbs each plus what kind of fluid is in them.
frnkeore ![]() Silver Level ![]() Joined: 07 May 2019 Location: Southern Oregon Points: 362 |
This is off of a chart that I have:
Gal Water weight 3½ lb/gal CaCl2 5lb/galCaCl2
Frank
1959 D17 Series I #24001+, '59 D14 '55 & '59 Ford 850 & 861 Ferguson TO 35 Deluxe, Oliver 70 and 5 more. |
Good info . Thanks
Ted J ![]() Orange Level ![]() ![]() Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
Thanks Frank andTed .
Edited by ACinSC - 04 Nov 2019 at 9:20am |
Post Reply ![]() |
