Need help with new starter for 7060 |
Post Reply ![]() |
TravisJ ![]() Bronze Level ![]() Joined: 02 Nov 2019 Location: Randolph, MN Points: 2 |
![]() ![]() ![]() ![]() ![]() Posted: 02 Nov 2019 at 5:27pm |
I got a new gear reduction starter for my 7060. It did not come with any instructions which would have been helpful because it is a bit different than the original. I hooked it up and nothing. Switched a couple wires a couple different ways and nothing. Good power coming to the starter but it won't even do anything when I cross the terminals. Im sure I
have something wrong, any pics or instructions would help. Also, what's the big stud terminal on the actual starter for?? Maybe that's my issue....
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24738 |
if you can, post a picture of what you have. It might not be the correct one. Local car mechanic here returns 1/4 of what they send him as it's the WRONG parts.....yeesh..
lowell66dart ![]() Orange Level ![]() Joined: 10 Jul 2013 Location: Paulina La. Points: 964 |
Do a Google search for 7000 series gear reduction starter. It will bring up and old post of mine from here when I put one on my 7060. It may help you. I don't have the tractor anymore.
That big stud on the actual starter is you new ground. You can also do a search for Delco Remy 8200433 39MT. That will bring you to some wiring instructions. Your going to like that starter. Edited by lowell66dart - 02 Nov 2019 at 6:02pm |
AC 6080 (8030,7060,200,175,D-17HC, 6040,160,6140 all gone) Farmall 1066 & 656 Hi-Clear (for sale), White 2-62 High Clearance, JD 4255 Hi Clear.
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8656 |
what brand is the one you got?
Moneypit ![]() Bronze Level ![]() ![]() Joined: 13 Sep 2018 Location: Barnesville mn Points: 81 |
Did you run a new heavy ground wire to it? Original starter didn’t have one
Post Reply ![]() |
