HD6 backhoe
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Topic: HD6 backhoe
    Posted: 02 Nov 2019 at 7:35am
There is an HD6 backhoe attachment for sale on eBay
NomoreJohnDeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NomoreJohnDeere Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2019 at 8:24am
with trailer!
HD3
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2019 at 8:45am
Have a AC 615 backhoe attachment off my HD4 - 14' dig depth - Cesna rotary piston swing motor mounted on top of swing .
 Kept thinking I would mount it onto another machine after selling HD4 but has set now for a few years as have the AC 715B TLB - have one cylinder now on my 715 as most parts interchange .
Post Options Post Options   Thanks (0) Thanks(0)   Quote NomoreJohnDeere Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2019 at 10:21am
HD3
Leop View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leop Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2019 at 12:45pm
I have never seen such an attachment. I didn't even know that backhoes could take much more than a different bucket on them much less somthing that big.
What does it do?
DonBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2019 at 1:57pm
I use to have a H3 loader/backhoe. It was extremely handy as you could drop or reattach the hoe unit in less than 5 minutes minutes. You pulled a couple of pins and then lifted the hoe 3-4 inches out of the lower hooks  using the stabilizers, release the hydraulic quick couplers and drive away. You reversed the procedure to reattach the hoe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2019 at 12:00am
Missing bucket linkages - for the price worth it .
About the same as the hoe i have - quick attach brackets are going to be a problem on a 5 or 6 - and you will need a diverter valve in your feed line to your valve body .
 Also that hoe runs on a higher pressure than a 5 or 6 hyd system . If you have a dozer - your pump is about 1/2 capacity needed to have any hoe speed
