301 oil pump adapter
bsallis180 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Topic: 301 oil pump adapter
    Posted: 01 Nov 2019 at 5:46pm
Looking to see if anyone has Interest in adapter (s) to make the older cam drive oil pump block to a crank drive?
I’m making a bolt on adapter as of right now the only machine work that will need done is to cut the front main cap down to a certain height.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2019 at 8:20am
Just use external belt drive pump.      MACK
This page was generated in 0.118 seconds.
