2016 Ford 550 |
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10936 |
Topic: 2016 Ford 550Posted: 31 Oct 2019 at 6:29pm |
My friends 550 , the running lights and tail lights won't work. All others and signals OK. What is likely culprit? Dealer is little to no help. Thanks Tracy
TMiller/NC
Joined: 11 Sep 2009 Location: Lenoir, NC Points: 1776 |
Thanks(1)
Posted: 31 Oct 2019 at 6:43pm |
Tracy, my neighbor has a F350 not sure of year, but fairly late model, was having problems with tail lights, found a loose ground near rear of frame on drivers side. It appeared to have not been tightened at factory. |
Tracy Martin TN
Posted: 31 Oct 2019 at 7:01pm |
miller, I will check that out. Thanks, Tracy
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25259 |
Posted: 31 Oct 2019 at 8:56pm |
could be a fuse..dang new trucks have 30-40-50 fuses in them ! My 97 F150 has THREE fuse panels.....my 57 Willys had 5 fuses...... hopefully you've got the owners manual, they DO list fuses, least mine does...
baverwolf
Joined: 24 May 2010 Location: SE Montana Points: 828 |
Posted: 31 Oct 2019 at 10:31pm |
Had same problem on my 2016 f250. It was a blown fuse caused by a wire that had gotten pinched. I'm guessing the 550 and 250 are wired the same so I'm gonna bet you have a blown fuse caused by a short somewhere.
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35684 |
Posted: 01 Nov 2019 at 6:03am |
Fuse blocks under the hood, tend to corrode really bad and have Lighting Relays as well to reduce amperage flow thru the Lighter duty switches, the relays are not well marked except in the manuals. The Relays are troublesome.
LeonR2013
Joined: 01 Jan 2013 Location: Fulton, Mo Points: 3500 |
Posted: 02 Nov 2019 at 3:50pm |
You need someone to work on it who has a high dollar ohm tester. My son is the guru on Ford electronics and that is what you will need for your truck. In fact that's what you need for all vehicles in the world today. Leon
