18.4 x 38 power-shift rims for 8030 |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8984 |
Topic: 18.4 x 38 power-shift rims for 8030Posted: 28 Oct 2019 at 10:19pm |
I would think salvage yards would have plenty. Brother in law has run 20.8's on 30in rows spraying and side dressing for 40+ years in a JD but I get the "make life easier" thing. I side dress with my 8070/18.4's and axle duals....just drive and don't look back. I figure if the neighbor can side dress with narrow track Cat,I can tromp the end rows with duals.
Edited by SteveM C/IL - 28 Oct 2019 at 10:21pm |
rieg
Posted: 28 Oct 2019 at 10:00pm |
Going with 42s would require different centers or new rims that would fit my 38 centers I don't want to put that much into it. Going with 18.4 x 38 rims would allow me to go with 13.6 x 28 on the front using my same rims which I hope will allow the tractor to turn shorter thus achieving two things. Thanks for your thoughts, helps me think through the options. Should be plenty of 18.4 x 38s out there.
rieg
Jordan(OH)
Joined: 11 Sep 2009 Location: Celina, OH Points: 1580 |
Posted: 27 Oct 2019 at 12:12pm |
Rare? 42s are everywhere.
Tim NH
Joined: 16 Oct 2012 Location: Lancaster NH Points: 1155 |
Posted: 27 Oct 2019 at 7:51am |
Here is a business that sells them.
HD6GTOM
Posted: 26 Oct 2019 at 7:01pm |
18.4x42 drop center rims with rails on them might not bolt up. I have put 18.4x38 tires on 20.8x38 rims. If you are mounting them with tubes make sure you use HD radial tubes in the tires. The 18.4x48 bias tubes were terrible.
DougG
Posted: 26 Oct 2019 at 5:24pm |
Pretty sure they sell new rims etc,, that will set it up right
rieg
Posted: 26 Oct 2019 at 4:53pm |
Yes I and that would be even better but those are as rare as hens teeth. Got a set I'll take them. Thanks for the comment guess I should have thrown that out there.
rieg
DanWi
Posted: 26 Oct 2019 at 11:36am |
Cant you go 18.4x 42s and keep the same size fronts?
rieg
Posted: 26 Oct 2019 at 11:29am |
I am looking for a pair of rims, would like to change from the 20.8s that I have. I need new tires so I thought it a good time to change out the rims and tires. I use the tractor for planting corn and side dressing. I would have to change out the front tires as well but the smaller size on the front would help with turning radius. I am in swoh if someone knows of a set for sale. thanks m rieger
rieg
