clean grain elevator
wheelbilly View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheelbilly Quote  Post ReplyReply Direct Link To This Post Topic: clean grain elevator
    Posted: 24 Oct 2019 at 10:59am
Any one ever replace center board on F3?  is difficult to do? Would I have to remove elevator from combine?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2019 at 7:20pm
Yes on remove....it is 2 pieces held together down center with bolts through board
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2019 at 8:18pm
I have no experience with replacing the board, but may I ask why it needs replaced on such a "newish" machine compared to our '79 F2? Just curious is all, have a feeling our machine is on "borrowed" time Cry
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2019 at 9:38pm
Hardest job is getting it out of grain bin.      MACK
soybreedingboy77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote soybreedingboy77 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2019 at 10:53pm
Good luck finding one. Couple of years ago I checked and they were NLA from AGCO
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2019 at 6:54am
I'm not so much familiar with F series, but if the center board on them is oak like on L/M series, I used to make them out of a piece of oak from the local lumber yard. Darrel
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2019 at 6:54am
We replaced one in the L3 last winter. Two guys works best to remove and reinstall the elevator. We took our worn out center board to local cabinet maker. He made a perfect match, bolt holes and all.
Leon B Mo
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheelbilly Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2019 at 9:07am
Its breaking up on the lower end.  Had a couple of pieces at the bottom causing cause slip clutch to go off.  Also a lot of extra beans not geting carried on up and loading auger and elevator.  about finished, will be winter project.
