Another repair done
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Topic: Another repair done
    Posted: 22 Oct 2019 at 4:06pm
Let a fella borrow my Log Splitter I built some years back. Worked fine on the old 180, 2000 psi hyd and 12gpm was great, he put it behind Ferd with 3500psi hyd, his step son in law tried to bust a 'Y' overpressured it and sprung the push plate floor table. He then commenced to try to weld it to make the screw up prettier only to fully lock the table down to the slide by bowing it further.
Got off my butt today unbolted the mess, cut away the push plate and replaced the 1/2" floor with a section of a 1" thick cutting edge I have, harder, more solid I HOPE, and all back together. Also trimmed the back pedestal for upper link clearance. SHOULD outlast Me!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2019 at 4:13pm
Good repair job. Going to let that fella borrow it again now that you have it fixed? LOL I am particular about who I lend my tools and equipment to because of that same problem . They screw it up and then try to cover it up. Got a few friends that I gladly lend to because they always return my stuff in better condition than it was when they borrowed it.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2019 at 5:08pm
You can cut down on the number that borrows it by asking for a $500 deposit until returned in good condition.😀
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2019 at 5:18pm
Heck I'm IMPRESSED someone USES a folding tape measure !!! WinkIt's got be an antique cause I've not seen one in a long,long time.
acd17toy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd17toy Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2019 at 7:03pm
  If some one wants to barrow my wood splitter I go with it at a cost $45.00 a hour including travel time.  Loaned it out once years ago  and it came back with  fire damage, found out later that the person left it to close to a brush fire. That cost me quite a bit of money to repair back to working condition.
Mactractor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2019 at 8:19pm
Nice job Dave. Add that splitter to the list of things you NEVER loan out. The one that starts with wife, dog, Chainsaw.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2019 at 8:21pm
It may get sold now that is fully functional and we no longer have a wood fueled heat source. And NO it will NOT be loaned or allowed borrowed again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2019 at 8:24pm
Got two of them that I still use occasionally if I have to measure for a counter top. About the only way I can get an accurate inside measurement. I think most building supply/hardware stores still carry them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2019 at 8:26pm
Think I have three of the rules, Old welder/mechanic aspect I have NOT lost yet and still available in most HDWE Stores. I still have one that has the Brass extension in the first Six inch length.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2019 at 9:20pm
I have a splitter almost like yours. been good to me for about 40 sum years. mine has an adjustable back plate and the wedge is on the cylinder. I also use it with my 180D. never had anything it couldn't split, once I told someone that if it wouldn't split something I could turn it a 1/4 turn (the wood) and cut thru it! he said BS, so I turned the wood chunk sideways and cut thru it like I said it would! lol...mine is hooked direct to the tractor hyd's, and i'm using a cylinder off a Cat road grader. never had to do anything to it yet as for fixing. they were made somewhere in KS. it was new when I bought it on a church benefit auction. I pretty sure yours and mine will outlast us! and I too do not loan it out, if someone wants wood split, they can bring the wood to me, i'll be glad to help!
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2019 at 8:10am
Construction Electricians use them, when running conduit, but they use what we called "inside readers", because the markings on the outside, when closed, from putting in and removing from your pocket.
Dusty
This page was generated in 0.305 seconds.
