WD UP GRATEED TO WD 45
1947WC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1947WC Quote  Post ReplyReply Direct Link To This Post Topic: WD UP GRATEED TO WD 45
    Posted: 21 Oct 2019 at 12:19pm
Any one know if the crank length is different on a wd and a wd45?
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2019 at 12:25pm
Crank is identical other than the stroke.  Will drop right in.  You'll want the right pistons for it and using the 45 air cleaner and carb will help with air flow.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2019 at 12:54pm
If you don't put a 45 manifold and carb on it,you're wasting you time. You can get by with WD air cleaner but 45 would be better.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2019 at 6:56pm
What are the differences in the WD and 45 manifolds? Is it the opening size where carb attaches? Friend of mine has a WD carb on his tractor and it pulls real good. Could be some changes made that we dont see??
Edited by Sugarmaker - 21 Oct 2019 at 6:57pm
This page was generated in 0.166 seconds.
