220 hydraulic pump
dirtschlinger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dirtschlinger Quote  Post ReplyReply Direct Link To This Post Topic: 220 hydraulic pump
    Posted: 21 Oct 2019 at 9:04am
I was plowing with the 220.  Noticed hydraulic fluid spraying everywhere on the left side of the tractor.  Picked the plow up and got it to the end of the field.  Didn't see anything spraying anymore.  I took off for home hoping to make it there.  Nothing spraying or leaking anymore.  Got it home and nothing appeared to be leaking.  As soon as I pushed the 3 point lever down fluid sprayed everywhere.  Looked like it was coming out of the front of the pump but hard to tell because of so much fluid spraying out.  I read that since I have the traction booster I have the dual pump.  So I'm thinking that part of the pump needs rebuilt but while I have the pump off should I rebuild the whole pump?  Would any hydraulic shop be able to rebuild or is it pretty straight forward and not a bad rebuild most people can do?  Looks like hydraulic pumps are not cheap.  Are there any tricks to taking the pump off that I need to watch for?  Any wisdom or advice is appreciated.  Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2019 at 12:07pm
I would think that two seal kits and a shaft seal would get you fixed up. No magic to removal. Two bolts, three lines and a suction hose.
Edited by DrAllis - 21 Oct 2019 at 12:07pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2019 at 12:57pm
Scribe housings so you get it back together right
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2019 at 9:35pm
Scribe pump at angel, not straight.     MACK
This page was generated in 0.089 seconds.
