B Transmission and Final Drive oil |
BenGiBoy
Joined: 11 Nov 2015 Location: Ashville, NY Points: 705 |
Topic: B Transmission and Final Drive oilPosted: 19 Oct 2019 at 3:27pm |
I have a reprint of the Operating Instructions / Maintenance manual for my B and it says SAE 20 in the transmission and differentials and im thinking of doing a fluid change.
What do you all use? Would 10W-30 engine oil be good for it? I'm thinking probably don't want too thin though, right?
Thanks all... BenGiBoy
'39 Model B
Tractors are cheaper than girls, remember that! |
CrestonM
Joined: 08 Sep 2014 Location: Oklahoma Points: 8479 |
Posted: 19 Oct 2019 at 5:16pm |
I use SAE 20 in mine, but I think most folks use universal hydraulic/transmission fluid.
HoughMade
Joined: 22 Sep 2017 Location: Valparaiso, IN Points: 714 |
Posted: 19 Oct 2019 at 5:27pm |
I use universal hydraulic/trans fluid. If you B has hydraulics (not all did), I wouldn’t use 10w30 motor oil.
1951 B
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90834 |
Posted: 19 Oct 2019 at 5:33pm |
I use 8 quarts of UTF in the trans / hydraulic/ bevel gear box , and 80-90 gear lube in the final drive drop box pan on each side.. Takes less than a quart on each side.
BenGiBoy
Posted: 19 Oct 2019 at 8:23pm |
Mine just has the PTO, no hydraulics.
Okay. Thanks all! Ben
'39 Model B
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8402 |
Posted: 19 Oct 2019 at 10:46pm |
keep in mind that SAE 20 weight, if i'm not mistaken is non-detergent
CTuckerNWIL
Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Posted: 20 Oct 2019 at 11:50am |
Nothing but Universal Transdraulic Fluid in my tractors.
Bill Long
Joined: 12 Sep 2009 Location: Bel Air, MD Points: 4556 |
Posted: 20 Oct 2019 at 6:05pm |
When we sold them newin the 30's to 50's we used NON DETERGENT SAE 20 wt oil. It worked fine. However, I have heard good reports on the UTF type oils.
In the final drives we used 140 but again there are better lubricants out there now. Take good care of my favorite. Good Luck! Bill Long
BenGiBoy
Posted: 21 Oct 2019 at 3:28pm |
Okay. I'll put something in it then, it's probably not super particular i'm getting the idea.
I'll let ya'll know what I use... Thanks all! Ben
'39 Model B
Gary
Joined: 13 Sep 2009 Location: Peterborough,On Points: 5911 |
Posted: 21 Oct 2019 at 4:28pm |
Just don't use a Detergent Oil in the Hydraulic. Apparently it will foam up. Gary |
BenGiBoy
Posted: 21 Oct 2019 at 5:52pm |
That makes sense, hydraulic oil probably has anti-foam agents or something in it.
'39 Model B
