TL 12 carburetor question
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Topic: TL 12 carburetor question
    Posted: 18 Oct 2019 at 6:37am
I recently acquired an early model TL 12. There is no choke on the carburetor. The holes for the shaft have plugs in them. Is this normal, or has someone done some modifications to it? Kind of wondering how it will be to start in the winter?
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2019 at 9:14am
should be same carb as wd45 or D17 depending on year.  just slap one on it.  you will need it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2019 at 6:47am
OK, another question. Where would the choke linkage be located in the 'cab'?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2019 at 6:18pm
If you use a choke cable, you can put it almost anywhere...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2019 at 9:29pm
I understand that, but, where was it from the factory?
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2019 at 7:22pm
I don't know on a TL12 but some others of that style and vintage had a choke rod, or cable, in the wall behind and to the side of the seat or in the panel below the front of the seat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2019 at 9:09am
i would need to go take a look at mine to be sure, because i didnt use it much before pulling the engine but im pretty sure the choke cable is located directly under the operator on the rh side above the brake lock.
This page was generated in 0.227 seconds.
