6080 PTO question/help
Adam (MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam (MO) Quote  Post ReplyReply Direct Link To This Post Topic: 6080 PTO question/help
    Posted: 13 Aug 2010 at 9:26am
Hello to all.  I am new to the forum but not new to Allis tractors.  I grew up a 175 and D17 IV on a small beef farm in central MO.  I recently purchased a 6080 (picture is attached if I did it correctly) and need assistance with the PTO.  When the PTO disconnect lever on the left below the seat is disengaged the tractor will start but when it is in gear with the PTO Clutch on the right disengaged and touching the two sensors/switchs below the tractor will not start.  Any thoughts/suggestions is greatly appreciated.  Do i need to switch th sensor/switch below the main PTO disconnect of the left?  Thanks for your help and all enjoy reading the forums on the Allis page.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2010 at 11:13am
Why do you want to start the tractor with it engaged? It is hard on the PTO to leave the handle pulled back all the time and will cause excessive wear.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam (MO) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2010 at 11:59am
Charlie - I do not leave the left PTO disconnect lever engaged all the time ony when I am using the PTO on frequently during the day.  When I have the left PTO disconnect level disengaged then I leave the PTO clutch forward to prevent possible problems that may occur as you stated.  I am just looking to get it fixed.  Thanks.
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2010 at 4:32pm
It sounds like you need the switch below the disconnect (on the left side of the seat). You can try unplugging it and running a jumper wire to act as if that switch is making contact. Also, as you probably know, the foot clutch must be pushed in all the way too. Sometimes the switches just need to be adjusted with the locking nuts that hold them in place.
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2010 at 5:08pm
ours acts up sometimes.  if it will not start, i disengage the clutch, start the engine and quickly pull the seasonal disconnect in gear before the gears have time to start spinning.  i've adjusted the switches a couple times but it seems to always act up at some point.
jerbear View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbear Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2010 at 8:37pm
    Adam,
           we recently had the same problem, it would start normal with the left lever disengaged and the PTO lever forward (when you're not using the PTO every day).  It would not turn over at all the other way.    The only thing wrong with ours was a rusty connection on the safety swith below the platform.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam (MO) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2010 at 8:23am
Thanks for taking the time to help with my question.
