D17 hyd reservoir Q
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Topic: D17 hyd reservoir Q
    Posted: 15 Oct 2019 at 10:08pm
I have a D17 series III. I'm trying to refill the power director/hyd reservoir with 821 equivalent oil but it doesn't want to flow from the fill in the PD compartment forward into the hyd pump compartment. This series III has the plug where the hyd dipstick normally is so it should be the combined reservoir with the p.d. oil. When I drained the oil it came out of both drain plugs and the lift arms were functional. Now the lift arms don't move so I pulled the front hyd drain plug and only a few drops came out. I filled the P.D. housing over the full mark on the dipstick, but still nothing. Any ideas?
www.awtractor.com
A&W TRACTOR 920-598-1287
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2019 at 11:07pm
To left and forward of gearshift lever, remove the breather/dipstick combination and check oil level. It should hold about 20 qts / 5 gal. did you replace the hydraulic filter?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2019 at 7:01am
There is a Allen plug on left side of torque tube above clutch pedal. Remove it to vent or put oil in there.        MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2019 at 7:01am
Add/refill the compartment with the proper amount of oil. Start the tractor and park it with the front wheels down and leave the engine idling for a few minutes. It will eventually come around. Common issue with an S-3.
Edited by DrAllis - 16 Oct 2019 at 7:01am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2019 at 8:36am
Thanks! Will try idling on an incline, I can always add through the transport valve return hole if it still doesn't fill up. And yes, i replaced the hyd filter.
www.awtractor.com
