Oil weight
Scooter90 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scooter90 Quote  Post ReplyReply Direct Link To This Post Topic: Oil weight
    Posted: 10 Oct 2019 at 9:29am
I’m trying to fire up a b that has been sitting for five years. Any suggestion or recommendations I should use for an oil weight ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2019 at 9:43am
probably SAE30 ?
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2019 at 9:55am
I use Rotella T4 15W40.  The manual said 10w in the winter and 30w in the summer, so a decent 10w30 with zinc and phosphorus would be fine.
...but I run Rotella 15w40 in everything I have that's old and relatively primitive and I've never had a problem.  Granted, my B doesn't come out when it is under 20 degrees.
1951 B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scooter90 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2019 at 10:38am
Thanks, that’s what I’ll try
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2019 at 9:02pm
After I overhauled my CA and wanted to use it for snow removal, I ended up going to Mobil 1 0W-30 so I could get it started fairly easy below 0. It was even 12v with a good starter. Since it sees so few hours a year combined with a warm building, it still gets the Mobil 1.
