Air conditioning 99 GMC
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: Air conditioning 99 GMC
    Posted: 07 Oct 2019 at 8:28pm
My compressor has bit the dust. About 6 months old. How much oil would be needed in system if I replace the compressor, dryer and orifice tube? This compressor made a noise from startup. O'reillys parts. Thanks Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2019 at 8:54pm
http://www.techchoiceparts.com/refrigerant-and-oil-capacities/gmc-light-truck
Additionally, General Motors issues Bulletin # 02-01-39-004B replacing PAG 150 oil with a lower viscocity oil. Thus, TechChoice now indicates PAG 46 (P46D) oil for those vehicles.
YearModelRefrigerantOil
TypeOuncesTypeOunces
ENVOY
2002-2004 All Engines w/ Front & Rear AC ... R134a 48.00 PAG 46 8.50
All Engines w/ Front AC Only ... R134a 29.00 PAG 46 7.50
1999-2001 All Engines R134a 31.00 PAG 150 8.50
1998 All Engines R134a 32.00 PAG 150 8.00
FULLSIZE PICKUP
2003-2004 All Engines - w/ Denso Compressor ... R134a 25.50 PAG 46 8.00
2002 All Engines - w/ Denso Compressor ... R134a 29.00 PAG 46 8.00
2000-2001 All Engines - w/ Denso Compressor ... R134a 29.00 PAG 46 8.00
All Engines - w/ HT6 Compressor ... R134a 32.00 PAG 150 8.00
1994-1999 All Engines - Crew Cab ... R134a 36.00 PAG 150 8.00
All Engines - Standard Cab ... R134a 32.00 PAG 150 8.00
1993 Standard Cab - w/ R12 ... R12 40.00 Mineral 8.00
Crew Cab - w/ R12 ... R12 48.00 Mineral 8.00
Standard Cab - w/ R134a ... R134a 40.00 PAG 150 8.00
Edited by steve(ill) - 07 Oct 2019 at 8:57pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2019 at 9:00pm
when you install the compressor and any other parts.... you will then pull a complete VACUUM.... so you are starting from scratch... ZERO... don't matter how many parts you replace, you add the same quantity afterwards.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2019 at 10:36pm
Steve, I wondered if the condenser and evaporator would trap any oil. I don't want to overfill oil amount. Thanks Tracy
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2019 at 10:48am
Tracy, maybe try asking google.  As I foggily recall, pulling a vac will eliminate all moisture (water vapor).
I never recall my vac puking any oil out that was extracted from the system.
Just got back from google.  It seems that all fingers point to the info that came with the new compressor.  Says some come with the correct amount of oil already added to the compressor.
Edited by Dave H - 08 Oct 2019 at 10:54am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2019 at 12:55pm
I guess if I removed the compressor and opened the hoses, I would be tempted to BLOW compressed air thru the system to make sure it was purged of any oil  / crap ... Then pulling the vacuum should get rid of any moisture.
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2019 at 6:34pm
actually, to do the job correctly, you should flush the system with an AC flush product before reassembly. Do that one time, and when you see the junk that comes out of that system and you will never do an AC job without flushing again. And, because you cannot properly flush the evaporator, many replace it also
I am still confident of this;
Wait for the Lord;
