8010 joystick
185turbo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 185turbo Quote  Post ReplyReply Direct Link To This Post Topic: 8010 joystick
    Posted: 07 Oct 2019 at 7:15am
Got a 8010 powershift with a westendorf loader. The loader is controlled with the remotes now but want to put a joystick on it to run loader. Does anyone know where to get a complete kit or how to piece one together ? Would need valve , joystick, cables and adapters to plumb into hyd system. Is it a pfc or closed center hyd system?
Thanks
185 turbocharged w/ 500 loader , WD
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2019 at 1:39pm
It is a closed center load sensing system. It would require a closed center load sense valve tee'd into the system. The load sense port is required to actuate the pump high pressure.
Surplus Center has a valve. It's not cheap, $570. The joystick controller and cables adds about $300.
A selector valve for the remotes would be cheaper.
acnh210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acnh210 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2019 at 9:33pm
I have one in an 8050. I bought it through westendorf (work for a dealer) it does not include hoses and was $2600 several years ago. A lot of work to install but worth it once it's in.
Terra Tiger, WD, 7040ps, 8050 with westendorf loader, 8050ps fwa.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 185turbo Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2019 at 9:42pm
I looked on surplus center and i cant seem to find a ccls joystick valve on there.. do you happen to know the part number of it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote acnh210 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2019 at 10:00pm
I beleive I still have the owner's manual. Just not sure where. I'll do some digging.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2019 at 5:54pm
The closed center load sense valve and joystick controller are listed separately. Do a search for "load sense" and "joystick".
The valve is a Prince 20 series
The cables and connections are also separate.
The controller is 9-6704-J
Post Options Post Options   Thanks (0) Thanks(0)   Quote 185turbo Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2019 at 7:00am
Thanks for the help i found the valve joystick and cables. I will just have to figure out how to plumb into the supply return n load sense now
toolcat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote toolcat Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2019 at 7:10pm
so why couldn't you just get a joy stick controller and proper length cables and use the existing factory valves unless you are trying to add more outlets to the system.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 185turbo Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2019 at 9:00pm
Only have 2 remotes , need 4
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2019 at 4:24am
The pressure line is the one with the hose going from the pump to the remote/lift valve. You can tee in there. A 3/4 JIC swivel run tee will make it easier.
The sense line is the 1/4 tube running from the pump to the valve. A JIC swivel run tee here. Easier to install at the valve end.
The return is a tube from the valve to the reservoir. I think it is 1 in.
JCFarms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JCFarms Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2019 at 8:16pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2019 at 5:19pm
That's the valve. I would get the one with the float position, especially for a loader.
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2019 at 1:43pm
I would like to get one of these,,will the joy stick and cables mount to that 9-20-2-LS? I have joystick and cables,,, when I got the 8010 with a westendorf loader, it had this on it, but the wrong valve, so,,, I took it off and just run loader to the rear remotes...I found out its not good to "deadhead" the load sense pump with a closed center valve,, but it may been a open center...I'm not sure,but it's non been there for a long time....
Post Options Post Options   Thanks (0) Thanks(0)   Quote 185turbo Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2021 at 7:07am
Any ideas on teeing into the return side of the system? The pressure and load sense are easy since they are hoses but not sure how to tie into the return since it’s a steel tube? Is there another place I could return the oil?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2021 at 7:24am
I've never done this, but have always felt you could remove the endplate on the hydraulic valve stack, drill and tap a hole that lined up with the return passage. Could also remove the cover plate under the PTO gears and drill/tap a hole in there as well, although it would need to be kept up tight to avoid hitting a rock rolling by.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2021 at 7:25am
Could return back to one of the sight bulb holes.             MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote 185turbo Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2021 at 7:46am
Ok . I’d rather not drill and tap if possible but will if I have to. there is a line on the front side of the right hand filter that goes forward possibly to oil cooler?
Would it be ok to plumb in the rear there?
The return tube from the remotes comes in on the rear side of the right hand filter..
Post Options Post Options   Thanks (0) Thanks(0)   Quote 185turbo Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2021 at 8:16am
I meant to say would it be ok to plumb in the return there, on the front side of the right hand filter
Post Options Post Options   Thanks (0) Thanks(0)   Quote 185turbo Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2021 at 10:48am
Are the sight glasses pipe thread ? 1/2? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2021 at 12:07pm
Not pipe thread. O-ring threads.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2021 at 1:15pm
The line going forward is the pump suction. The one on the top is the return from the valves.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 185turbo Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2021 at 10:28am
Cant seem to find the correct oring thread for the sight glass. 1/2 nipple will screw right in though , any ideas thanks
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2021 at 8:45pm
1/2" fitting was all we ever used.
