Is this HD7W stock or home made crawler?
Randy_Larson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy_Larson Quote  Post ReplyReply Direct Link To This Post Topic: Is this HD7W stock or home made crawler?
    Posted: 05 Oct 2019 at 8:57am
I have never seen such a unit. Is this all Allis-Chalmers or something that was adapted for bare root tree harvesting?
https://www.machinerytrader.com/listings/construction-equipment/for-sale/26779697/1950-allis-chalmers-hd7w
Thank you for your time to look or reply.
G,D10,D12,D14,D15,D17gas,D17 diesel,D19 Diesel, D21 Series II,160,190, B1,Bumble Bee 10,B1,HB 212,ACC 30 forklift and snap-coupler equipment
NomoreJohnDeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NomoreJohnDeere Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2019 at 10:32am
It would have to be custom
redo two machines undercarriage with that bad boy
HD3
200Tom1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2019 at 8:01pm
That is an actual AC crawler made for working trees.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2019 at 9:14pm
Bailey Nursery here had a HD4 set up the same way - they look wierd is all I can say .
Who built the units ? I always figured they were shop built locally and not factory.
 Now trying to find parts for the old HD7 machines with a 3-71 is like finding hens teeth .
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2019 at 3:14pm
Yes Coke shop built. In 83 when at a Berco track dealer that also shared facilities with several independent mechanics. They were building a nursery tree lifter on a Cat D4 frame.
Edited by Ray54 - 24 Oct 2019 at 3:15pm
acken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acken Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2019 at 6:36am
We have modified a number of them in our shop, as well as built from scratch. Clearance under the belly ranges from 4-8 feet, depending on what we are digging. The HD4 that was here I believe was done by Sweeney in the Twin Cities, MN. GK Machine in Oregon still builds a tall crawler from scratch. Pardon the off color attached, easiest picture to find.
This page was generated in 0.309 seconds.
