5015 injection pump
Maya View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Maya Quote  Post ReplyReply Direct Link To This Post Topic: 5015 injection pump
    Posted: 02 Oct 2019 at 9:23am
Please help
I have a AC 5015
With a seized injection pump.
Where can I get a replacement or rebuild parts?
ACmowerguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2019 at 11:00pm
There is a parts yard that specializes in these units. In general, parts are hard to find for the 5015 tractors.
If they don't have something they might be able to point you in the right direction. Depending on who made the injection pump, a Diesel injection pump repair shop might be able to help you out.
jofo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jofo Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2022 at 11:10am
Hello,
I had an issue with my diesel injection pump and wanted to share how I reprimed it. It started when I broke the fuel filter bowl and all the fuel drained out of the pump. I replaced the bowl and added fuel, but I was getting no fuel out of the pump. It took several tries, but I used an oil transfer syringe from an auto parts store, and forced fuel into each of the injector pumps (3). Initially, I was only able to get fuel pumping from 2 of the pumps, but I figured I could get the engine to start anyway. I tightened all the fittings and finally got it started.
I read a sad story about someone who replaced their pump and still couldn't get their pump primed. Hopefully, this might help.
jofo
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2022 at 4:13pm
Try    "injumpEd" here on the forum.  He does and I know someone that he did a 5015 pump for.  Everyone swears by him.  Den
Own 4 wheel 20, 2-5015, 5020 and associated equipment and 2 electric forklifts.
