Wd 45 charging system issue
Colt1986 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Colt1986 Quote  Post ReplyReply Direct Link To This Post Topic: Wd 45 charging system issue
    Posted: 29 Sep 2019 at 11:54am
I just completely rebuilt my 1955 wd 45.new wiring harness new light switch(second one).I wired everything per instructions from the wire harness kit I got from brillman for 6 volt positive ground system.I had my generator rebuilt and a new cutout put on.The resistor in the switch glows cherry red and I can't get the system to charge I don't know what I am doing wrong any help on this issue would be greatly appreciated.I redid the grounds to the dash panel thinking that might have something to do with it or the cheap light switch I had used I replaced the switch with a cole and hersee and it still continues to do the same thing I'm clueless
acd17toy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd17toy Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2019 at 6:14pm
 The brillman wiring instructions may be wrong, fallow the diagram  in your owners manual.
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2019 at 6:56pm
Is the F terminal on the generator connected to the switch?
BigGuy1000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BigGuy1000 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2019 at 9:44pm
IF you have the right switch this is the correct wiring:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2019 at 6:45am
First of all, those aftermarket 3 position switches are junk! If you're going to keep it 6V, put the correct 3 position switch in it. The correct one is the round Delco with fuse tower. Those aftermarkets cause many people headaches and burn up new wiring harnesses. (including my own harnesses)  I have no idea what Brillman's wiring instructions are, but I would go by a service manual or I can send you in the mail one of my color coded wiring diagrams to use. We have the correct OEM Delco 3 position switch in stock rebuilt ready to go if interested. Double check your wiring. Also, make sure your Ammeter is good. I've seen faulty Ammeters cause these problems also...
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2019 at 8:13am
Agree with Steve, have saw Amp gauge burn into inside. Current has to travel through Amp gauge.        MACK
