Battery cable size?
caRon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote caRon Quote  Post ReplyReply Direct Link To This Post Topic: Battery cable size?
    Posted: 27 Sep 2019 at 11:23am
I have some 2/0 battery cables. Are they too big for a 12 Volt CA tractor, or is bigger better?
CA Tractor
Rhoadesy_65 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rhoadesy_65 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2019 at 11:57am
Bigger wires have less resistance, just like a bigger pipe lets more water flow. Less resistance means it will carry a higher amperage, so bigger the better.
Farmin' with 1981 7010 PD, Great Grandpas 1947 Farmall H, JD 7000 planter, JD model B drill, NH 316 Baler, NH 1411 Discbine ,JD 100 8 Shank Chisel. Darke County OH
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2019 at 12:26pm
I use no. 2 cables on my diesels. 2/0 is pretty big but will work.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2019 at 1:06pm
Think of electricity as water.
Pressure/Voltage
Flow/Amps
Pipe size/Wire size
Dusty
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2019 at 7:51pm
I have 2/0 cables on a 12 volt WD, bigger cables are also safer as they will not heat up as much with higher amps. Only minus is they are harder to bend and shape.
Edited by Bill_MN - 27 Sep 2019 at 7:52pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2019 at 7:55am
2/0 cables are a bit overkill, but will work just fine. 1 gauge would be the norm for 6V but is a nice step-up for 12V systems. I build my cables in the 1 gauge for both systems. The 2/0 would be real good for the 6V for the amperage factor...
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote caRon Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2019 at 8:34am
thanks
CA Tractor
